Dear TI,
I want to develop a microcontroller circuit which should have 4 channel 16bit adc, Ethernet and serial port. Could anyone suggest what microcontroller, adc, Ethernet i have to use.
Sivakumar
Dear TI,
Sivakumar
Hi Sivakumar,
A good place to start for Ethernet microcontroller is the TM4C129. Look at the EK-TM4C1294XL LaunchPad. For 16-bit ADC with 4 channels you may need to get a separate ADC from TI. There are some in BoosterPack form or others that have seperate EVM boards for evaluation. Check out the adc161s626evm for example. Another good microcontroller choice will be the C2000 family, however you will need to come up with your own external ethernet solution. For example you can investigate the LAUNCHXL-F28377S.
