• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Amplifiers » Audio Amplifiers » Audio Amplifiers Forum » Active subwoofer for TAS5706
Share
Audio Amplifiers
  • Forum
  • E2E Wiki
Options
  • Subscribe via RSS
Check out
Analog Wire blog
  • $core_v2_blog.Current.Name
    This amplifier doesn't exist...now what!?
    Posted 18 hours ago
    by Xavier Ramus
    Sometimes it’s impossible to find an amplifier with the...
    Cable equalization 101 – Automating your design
    Posted 3 days ago
    by Hooman Hashemi
    Judging by the number of views on a post related to numerical...
    RS-485 - Who says you can't teach an old dog new tricks?
    Posted 7 days ago
    by Neel Seshan
    Would you agree that RS-485 has turned out to be one of the most...
This question is answered
Hanns
Posted by Hanns
on Jan 19 2012 05:39 AM
Intellectual810 points
Hi all!
What external components are required in order to get a low level signal suitable for a external active subwoofer connected via the subwoofer PWM output of the TAS5706B amplifier?
I can only find examples on how to connect subwoofer amplifiers such as the TAS5602 power stage.
Maybe someone could even provide an example schematic.
Thank you.
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Don Dapkus
    Posted by Don Dapkus
    on Jan 19 2012 14:32 PM
    Guru102005 points
    Hi, Hans,
    I am not sure I follow what you are trying to do.
    Do you want to use the TAS5602 for a sub-woofer with the TAS5706?
    OR, do you want to use some powered sub-woofer with an analog input?
    -d2
    Don Dapkus
    Audio Applications Engineering Manager
    Dallas, TX USA
    Report Abuse
    • Reply
  • Hanns
    Posted by Hanns
    on Jan 19 2012 15:06 PM
    Sorry for being unclear - I want to connect the subwoofer PWM output of the TAS5706 to a convential (consumer product) active subwoofer, i.e. an ordinary sub with a built in amp of its own. That is, yes I want to use a powered sub with line level analog input.
    My question is what component(s) I need to have between the PWM output and the line input of the sub.
    Hanns
    Report Abuse
    • Reply
  • Don Dapkus
    on Jan 20 2012 08:38 AM
    Guru102005 points
    Hanns,
    No worries!
    I have never tried this, but you should be able to simply LPF (low-pass filter) the PWM outputs with an RC filter and feed it to your amp. I'd set the corner freq around 30 kHz or so.
    We often do this with HP (headphone) amps, so I don't expect any issues. For an example, check out the TAS5717 schematic R13/C13 and R9/C20 are these LPF.
    -d2
    Don Dapkus
    Dallas, TX USA
    Report Abuse
    • Reply
  • Hanns
    Posted by Hanns
    on Jan 20 2012 08:55 AM
    That's great, I'll try this. Thank you.
    Report Abuse
    • Reply
  • Hanns
    Posted by Hanns
    on Jan 20 2012 14:33 PM
    Sorry, exactly what shematic in what document are you referring to, do you mean the evm?
    Report Abuse
    • Reply
  • Don Dapkus
    on Jan 20 2012 14:40 PM
    Guru102005 points
    Hanns,
    Yes, sorry, I forgot that part. The EVM schematic almost at the end of the EVM Users Guide. It's a little bit complicated b/c there is a jumper that decides the source of the HP - either PWM from the TAS5717, or analog-input from another chip. But, it's got the LPF that I was suggesting.
    -d2
    Don Dapkus
    Dallas, TX USA
    Report Abuse
    • Reply
  • Hanns
    Posted by Hanns
    on Jan 20 2012 15:50 PM
    Verified Answer
    Verified by Hanns
    Ok, I think I got it. Thank you.
    Report Abuse
    • Reply
  • Hanns
    Posted by Hanns
    on Jan 22 2012 10:23 AM
    So basically I configure the tas5706 for 2xbtl + sub like described in appendix C of the EVM user guide and the simply connect sub_pwm+ and sub_pwm- to the +/- RCA line input terminal on the back of the sub with a little filter in between. Correct? So no need for a pre-amp or anything like that?
    Report Abuse
    • Reply
  • Don Dapkus
    on Jan 22 2012 10:28 AM
    Guru102005 points
    Hanns,
    Remember, you need an LPF in there, and I doubt your sub has fully differential inputs, so you will need to go thru a differential to single-ended conversion, too. But, as a bonus, you can use an active LPF in that case!
    -d2
    Don Dapkus
    Dallas, TX USA
    Report Abuse
    • Reply
  • Hanns
    Posted by Hanns
    on Jan 22 2012 10:56 AM
    Ah, so I need like a line driver and an LPF, yes?
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
