Texas Instruments
  • Samples Cart - Add Samples Samples & Purchase Cart
  • Contact Us
  • TI Worldwide: United States
  • my.TI Login
  • Products
  • Applications
  • Design Support
  • Sample & Buy
  • All Searches
TI Home » TI E2E Community » Support Forums » Amplifiers » Audio Amplifiers » Audio Amplifiers Forum » TCA 2465 power opamp replacement needed MANY 1000's
  • Join
  • Sign In with my.TI Login
TI E2E™ Community
  • Home
  • Support Forums
  • Videos
  • Blogs
  • Groups
  • More ...
  • Go
  • Advanced Search
Share
Details
Rate This
  • 2 Replies
  • 2 Subscribers
  • 233 Views
  • Posted3 months ago
Options
  • Subscribe via RSS
Tags
  • /CLIP
  • /RESET
  • 25W amp
  • 3D
  • 50W Audio Amplifier
  • 50W spkr
  • 5630 chip 2.1
  • 5717 biquad
  • 8051
  • AD mode
  • ADA8000 TL074C TL07x op amp
  • AGND
  • amp
  • amplifier
  • Amplifiers frequency response
  • analog guru
  • APA power supply
  • AUDIO
  • Audio Amp
  • audio amplifier
  • Audio Amplifier application issue(TPA2015D1)
  • AUDIO GROUND
  • audio op amps
  • balanced microphone
  • BST cap
Forum - Title
Audio Amplifiers
Audio Amplifiers
Welcome to the Audio Amplifiers Section of the TI E2E Support Community. Ask questions, share knowledge, explore ideas, and help solve problems with fellow engineers. To post a question, click on the forum tab then "New Post".
  • Get this RSS feed
  • Home
  • Forum
  • Design Notes
New Post
This question is answered
Roland Shaak
Posted by Roland Shaak
on Feb 11, 2012 11:17 AM
Prodigy40 points
so i was thinking i could use an OPA2544 on a mini pcba "pin swapper" and appropriate connections for pins that differ from the TCA 2465  to get a 9 pin sip package (5 tca’s were used and whomever designed the circuity that used it simply MONKEYED it!!!!!!!!!!!!  Used as fan motor drivers, and environmental control (flapper) contol.  They fail like mad and the TCA’s are just not available anymore so I think I could use this chip as a replacement or does anyone have a better thought(s)
HELP -pleeeeeeze!  1000's of units each using 5 tca's (or) opa's
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • John De Celles
    Posted by John De Celles
    on Feb 13, 2012 6:17 PM
    Prodigy500 points
    Hi Roland,
    It does look like the OPA2544 is a similar IC, albeit with some better specifications. Without knowing your design requirement details, it looks like the OPA2544 has a higher current limit, slew rate and supply voltage and probably most importantly a lower package thermal resistance for driving power. Based on these specs compared to the TCA 2465, I'm sure that the OPA2544 would perform more than adequately. Another option that you may also want to consider is the LM1876. This is a similar part to the OPA2544 with the added benefit of having a highly protected output stage through its SPiKe Protection. There are some slight specification pluses and minuses with the LM1876 over the OPA2544, so I'll let you evaluate their differences, but either part could replace the TCA2465.
    I hope this helps.
    JD
    Report Abuse
    • Reply
  • Roland Shaak
    on Feb 17, 2012 5:28 PM
    Verified Answer
    Verified by Roland Shaak
    Prodigy40 points
    Well thanks JD i'll look over the alternate part you suggested - R
    The beefed output protection is a welcome addition since whomever designed the darn thing musta had a deal with the chip maker - try to find any?
    Thanks a bunch...i'm a laser dude...
    Report Abuse
    • Reply
Share
ALL CONTENT AND MATERIALS ON THIS SITE ARE PROVIDED "AS IS". TI AND ITS RESPECTIVE SUPPLIERS AND PROVIDERS OF CONTENT MAKE NO REPRESENTATIONS ABOUT THE SUITABILITY OF THESE MATERIALS FOR ANY PURPOSE AND DISCLAIM ALL WARRANTIES AND CONDITIONS WITH REGARD TO THESE MATERIALS, INCLUDING BUT NOT LIMITED TO ALL IMPLIED WARRANTIES AND CONDITIONS OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE, TITLE AND NON-INFRINGEMENT OF ANY THIRD PARTY INTELLECTUAL PROPERTY RIGHT. TI AND ITS RESPECTIVE SUPPLIERS AND PROVIDERS OF CONTENT MAKE NO REPRESENTATIONS ABOUT THE SUITABILITY OF THESE MATERIALS FOR ANY PURPOSE AND DISCLAIM ALL WARRANTIES AND CONDITIONS WITH RESPECT TO THESE MATERIALS. NO LICENSE, EITHER EXPRESS OR IMPLIED, BY ESTOPPEL OR OTHERWISE, IS GRANTED BY TI. USE OF THE INFORMATION ON THIS SITE MAY REQUIRE A LICENSE FROM A THIRD PARTY, OR A LICENSE FROM TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Products | Applications | Design Support | Sample & Buy RSS
TI Worldwide | About TI | Contact Us | Investor Relations | Press Center | Corporate Citizenship | Careers | Tags | my.TI Login | All Searches | Site Map
© Copyright 1995- Texas Instruments Incorporated. All rights reserved. Trademarks | Privacy Policy | Terms of Use
