• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Amplifiers » Audio Amplifiers » Audio Amplifiers Forum » TPA2100P1 evm driving Murata Piezo speaker
Share
Audio Amplifiers
  • Forum
  • E2E Wiki
Options
  • Subscribe via RSS
Check out
Analog Wire blog
  • $core_v2_blog.Current.Name
    RS-485 - Who says you can't teach an old dog new tricks?
    Posted 2 days ago
    by Neel Seshan
    Would you agree that RS-485 has turned out to be one of the most...
    Filter for thought
    Posted 4 days ago
    by Soufiane Bendaoud
    Have you ever wondered how engineers designed active filters...
    Let’s take this driver out for a spin
    Posted 9 days ago
    Before I suggest a suitable op amp to drive an ADC, I look at...
This question is answered
chrisw957
Posted by chrisw957
on Mar 13 2012 17:56 PM
Intellectual430 points
Should the TPA2100P1 EVM be able to directly drive a Murata piezeo model VSLBG1914E1400-T0?
http://search.murata.co.jp/Ceramy/CatalogAction.do?sHinnm=?&nbsp&sNHinnm=VSLBG1914E1400-T0&sNhin_key=VSLBG1914E1400-T0&sLang=en&sParam=VSLBG1914E1400-T0
It appears to be a fairly standard piezo speaker, 0.9uF, 200 to 20khz, etc...
We have it connected, but out+ and out- seem to be exactly the same, so there ends up being no differential signal across the piezo, and we get no audio.
Out signal is around 300khz, 10V square wave when audio is present at the input.
Thanks.
TPA2100P1
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Don Dapkus
    Posted by Don Dapkus
    on Mar 13 2012 23:28 PM
    Guru101635 points
    Hi, Chris,
    Hmmm, that's odd. It looks like the TPA2100P1 should be able to drive your piezo. It actually sounds like maybe one of the output filter elements is broken.
    If you look before the output filter (L2 and R5) do you see the outputs in phase?
    Note, they will be in phase with no input signal.
    Also, please note that we have used a shorting input jack on this EVM... If you drive your signal into J2, you must put an RCA plug into the input jack, or it will short out your input signal. That actually sounds like what's going on here.
    -d2
    Don Dapkus
    Audio Applications Engineering Manager
    Dallas, TX USA
    Report Abuse
    • Reply
  • Kumar Bhatia
    Posted by Kumar Bhatia
    on Mar 15 2012 16:08 PM
    Verified Answer
    Verified by Don Dapkus
    Prodigy30 points
    Hi Don / Chris. Just to confirm, we just tested the same EVB a few minutes ago with the same Murata Piezo speaker for a pending design. Our wiring was direct to the RCA jack and after wasting some time, we noted the short between the RCA jack. Thanks for this post - should have read it sooner. After we cut the trace from the "hot" of the RCA jack, the audio is playing from the Murata 1913 Piezo (24 db setting). We are operating the EVB @ 3.3 volts. The TPA2100 is on the approved Murata list of devices. Thanks.
    Kumar
    Report Abuse
    • Reply
  • Don Dapkus
    on Mar 15 2012 16:57 PM
    Guru101635 points
    Yay! Sorry we use that pesky RCA jack...
    Don Dapkus
    Dallas, TX USA
    Report Abuse
    • Reply
  • chrisw957
    Posted by chrisw957
    on Apr 04 2012 10:12 AM
    Apparently it turned out to be a bad eval kit.  Mouser exchanged it for us, and the new one worked right off the bat.
    Thanks.
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
