• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Amplifiers » Audio Amplifiers » Audio Amplifiers Forum » TAS5704 dropouts when MCLK not aligned to SCLK/LRCLK
Share
Audio Amplifiers
  • Forum
  • E2E Wiki
Options
  • Subscribe via RSS
Check out
Analog Wire blog
  • $core_v2_blog.Current.Name
    RS-485 - Who says you can't teach an old dog new tricks?
    Posted 1 day ago
    by Neel Seshan
    Would you agree that RS-485 has turned out to be one of the most...
    Filter for thought
    Posted 2 days ago
    by Soufiane Bendaoud
    Have you ever wondered how engineers designed active filters...
    Let’s take this driver out for a spin
    Posted 8 days ago
    Before I suggest a suitable op amp to drive an ADC, I look at...
This question is answered
Bjoern Fruehsorge
Posted by Bjoern Fruehsorge
on Mar 23 2012 07:02 AM
Prodigy35 points
Hello community,
our application uses several TAS5704 in bridged mode with the following parameters:
MCLK: 12.288 MHz
LRCLK: 48.000 kHz
SCLK = 64 x LRCLK
Interface format: I2S
The application runs well at room temperature, but below ~15degC we observed perodical droputs (period ~1Hz, width: ~13.5ms) on the output signal.
The phase between the rising edges of MCLK and LRCLK was ~10ns. After we shifted the LRCLK phase-aligned to MCLK, the error probability got lower. After exactly aligning both clks to each other, we see no errors anymore.
We have checked all setup/hold requirements for the serial interface, they are well within the specifications and fully compliant to the datasheet.
Whats going on here? I cannot find any statement in the datasheet that requires MCLK and LRCLK zero-phase-aligned to each other.
I would appreciate feedback as soon as possible.
Thanks and regards,
Bjoern
SCLK LRCLK TAS5704 dropout MCLK
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Don Dapkus
    Posted by Don Dapkus
    on Mar 24 2012 07:53 AM
    Guru101625 points
    Hi, Bjoern,
    This is a pretty old part - the I2S receiver may not be as robust across temp as we'd like wrt mis-aligned clocks... Let me have someone look into it, but I expect it is what it is.
    What's generating your clocks?
    -d2
    Don Dapkus
    Audio Applications Engineering Manager
    Dallas, TX USA
    Report Abuse
    • Reply
  • Bjoern Fruehsorge
    on Mar 26 2012 02:45 AM
    Prodigy35 points
    Hi Don,
    our development and product lifecycles are rather long, so this part was "new" as we started the design.
    We have a standard 50ppm crystal oscillator generating the MCLK with 12.288 MHz. The clock is buffered with a TI CDCVF310 clock driver towards six TAS5704 and to a Xilinx Spartan-3A FPGA, which generates the I2S protocol.
    It is very important for our customer to get an evidence _why_ our solution works, so please provide some details about the mentioned (missing?) robustness across temp.
    Björn
    Report Abuse
    • Reply
  • Ravi Singh
    Posted by Ravi Singh
    on Mar 26 2012 17:30 PM
    Verified Answer
    Verified by Ravi Singh
    Mastermind18570 points
    Hi Bjorn,
    I am looking into this for you, meanwhile, can you please address the follow-up questions below?
    1.) You mentioned the system has been in use for a while, so has the issue shown up now with a new test procedure / test-conditions?
    2.) How many devices or systems show this behavior?
    3.) When the issue is resolved using zero-phase clocks, are the clocks provided with zero-phase during temperature ramp-down (from 25C to 15C) or are they provided after the system shows the issue at 15C?
    4.) How does phase difference between SCLK & LRCLK look in the system? Can you please post a screen-shot of the I2S clock & data lines in the two cases (i.e. when issue is seen and when it is resolved)?
    Ravi Singh
    Audio Applications Engineer.
    Ravi Singh
    Report Abuse
    • Reply
  • Bjoern Fruehsorge
    on Mar 27 2012 01:25 AM
    Prodigy35 points
    Hi Ravi,
    here are answers to your questions:
    1) We use only one production batch with components procured in Q3/2009.
    2) All (six) TAS5704 within the affected systems show this behaviour.
    3) The clock configuration can only be changed by means of FPGA updating, so the zero-phase configuration is present since power-on (tested ramp-down and after "cold" start below 15C).
    4) Unfortunately I have not a screenshot, but the phase difference between SCLK and LRCLK is exactly what the data sheet requires (LR clock switching on the falling edge of SCLK) in both test conditions. I only changed the phase difference between MCLK and the I2C signals.
    Björn
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
