• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Amplifiers » Audio Amplifiers » Audio Amplifiers Forum » Interchannel delay on PWM Processor TAS5508C / tas5342ddv6evm
Share
Audio Amplifiers
  • Forum
  • E2E Wiki
Options
  • Subscribe via RSS
Check out
Analog Wire blog
  • $core_v2_blog.Current.Name
    This amplifier doesn't exist...now what!?
    Posted 1 day ago
    by Xavier Ramus
    Sometimes it’s impossible to find an amplifier with the...
    Cable equalization 101 – Automating your design
    Posted 4 days ago
    by Hooman Hashemi
    Judging by the number of views on a post related to numerical...
    RS-485 - Who says you can't teach an old dog new tricks?
    Posted 8 days ago
    by Neel Seshan
    Would you agree that RS-485 has turned out to be one of the most...
This question is answered
Boris Designer
Posted by Boris Designer
on Apr 03 2012 04:01 AM
Prodigy30 points
using the evaluation kit tas5342ddv6evm with TAS5508 I managed to set volumes, EQ's etc. but I've questions about Interchannel delay setting :
- The delays correspond to cycles of the high-speed internal clock, DCLK [TAS5508C datasheet]. But what is DCLK and it's frequency?
-Trying to set and measure delays between channels I could not recognize an impact. I measure the acoustic signal and estimate to be able to detect delay changes down to 0.2ms. Is the maximum interchannel delay <~ 0.2ms or is my register setting procedure not correct? With TAS5508GUI V4 a muted channels, write delay values to the registers 0x1B and following and then unmuted channels.
Any help appreciated as setting Interchannel delays is vital for evaluation/application.
Class D AUDIO Class-D
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Don Dapkus
    Posted by Don Dapkus
    on Apr 03 2012 07:22 AM
    Guru102005 points
    Hi, Boris,
    The ICD (Inter Channel Delay) basically controls the h-bridge timing and is used to optimize THD levels. I can't find the optimal ICD settings right now, but let me check around and see if I can locate them.
    -d2
    Don Dapkus
    Audio Applications Engineering Manager
    Dallas, TX USA
    Report Abuse
    • Reply
  • Boris Designer
    on Apr 03 2012 11:19 AM
    Prodigy30 points
    Hi Don,
    thanks for your reply! So the purpose of this delays is not what I thought.
    Would be nice to let us know the optimal Inter Channel Delay values for the Digital Power Amplifier Stage TAS5342A which is on the Kit tas5342ddv6evm
    - or to confirm that the TAS5508C defaults are ok for low THD.
    Report Abuse
    • Reply
  • Don Dapkus
    on May 15 2012 09:05 AM
    Guru102005 points
    Hi, Boris,
    Sorry for the delay. Are you still working on this?
    -d2
    Don Dapkus
    Dallas, TX USA
    Report Abuse
    • Reply
  • Boris Designer
    on May 16 2012 01:47 AM
    Prodigy30 points
    Hi Don,
    yes I do.
    Report Abuse
    • Reply
  • Tuan Luu
    Posted by Tuan Luu
    on May 16 2012 21:00 PM
    Verified Answer
    Verified by Don Dapkus
    Mastermind25885 points
    Hi Boris:
    D clock is 196.6 MHz.  As Don mentioned, it is used for improving harmonic distortion and cross-talk between adjacent channels.  The default values on the chip work best on our characterization board.  We don't have a set of values for the evaluation board.  The values vary with different layout but in general default values work best.
    Tuan
    Audio Applications
    Texas Instruments, Inc.
    Report Abuse
    • Reply
  • akarapan sawatdipakdi
    Posted by akarapan sawatdipakdi
    on Jan 17 2013 01:17 AM
    Prodigy30 points
    1) How much different impact to THD between best and worst setting of ICD ?
    2) I checked the waveform of channel 1-4, It seem to be always BD modulation when set to 2.1 mode even when config is AD. (TAS5711). Is it correct?
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
