• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Amplifiers » Audio Amplifiers » Audio Amplifiers Forum » tas5706 subwoofer output revisited
Share
Audio Amplifiers
  • Forum
  • E2E Wiki
Options
  • Subscribe via RSS
Check out
Analog Wire blog
  • $core_v2_blog.Current.Name
    RS-485 - Who says you can't teach an old dog new tricks?
    Posted 1 day ago
    by Neel Seshan
    Would you agree that RS-485 has turned out to be one of the most...
    Filter for thought
    Posted 2 days ago
    by Soufiane Bendaoud
    Have you ever wondered how engineers designed active filters...
    Let’s take this driver out for a spin
    Posted 8 days ago
    Before I suggest a suitable op amp to drive an ADC, I look at...
This question is answered
Hanns
Posted by Hanns
on Apr 03 2012 16:39 PM
Intellectual810 points
Hello!
Call me stupid but I'm not getting how the sub- and sub+ outputs of the TAS5706b are meant to be used. I get a nice bass sound if I take either single one of them and apply an LPF with a ~300Hz cut-off frequency. The only difference I can see between the two is a minor phase shift.
Once and for all, which alternative below is true about the sub- and sub+ signal pair of the TAS5706b?
a) I can use either of them (doesn't matter which) and LPF that
b) I must logically AND them together and then LPF that
c) They two are differential outputs to minimize distortion and I must use a differential amplifier on them and then LPF that.
d) I should do something else. If so please explain what to do and how to do it
Could someone please tell my which option is true so that I can sleep well at night :-)
Thank you very much!
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Don Dapkus
    Posted by Don Dapkus
    on Apr 04 2012 22:56 PM
    Guru101625 points
    Hi, Hanns,
    STILL with the sub-woofer, eh? :)
    Seriously, this is designed to be a differential signal out, but it is controlled by software (the bane of my existence...). Look at register 0x25. It depends on how you route the sub-woofer signal.
    The default is ch5 to sub_pwm-, and ch6 to sub_pwm+. So, depending on how you have ch5 and 6 configured, you will get different stuff out of the sub_pwm pins.
    -d2
    Don Dapkus
    Audio Applications Engineering Manager
    Dallas, TX USA
    Report Abuse
    • Reply
  • Hanns
    Posted by Hanns
    on Apr 05 2012 03:33 AM
    Hi Don!
    Yep, still struggling with this and believe me, I have certainly been looking at these registers :-)
    Anyway, this is an excerpt of my current config:
    0x20 = 00-89-77-7A (ch6 (BTL–) to ch5—BTL pair to ch6)
    0x21 = 00-00-41-03 (bass management to ch6)
    0x25 = 01-02-13-45 (ch6 to sub+)
    I take it, this means I get the desired bass-signal from the sub+ line and so I could just use that only and leave sub- floating. Correct?
    Or maybe I should change register 0x21:
    0x21 = 00-00-42-03 ((L'+R')/2 to ch6)
    This would get me a mono-downmixed signal on sub+, correct?
    Report Abuse
    • Reply
  • Ravi Singh
    Posted by Ravi Singh
    on Apr 22 2012 21:25 PM
    Verified Answer
    Verified by Ravi Singh
    Mastermind18570 points
    Hi Hanns,
    The Sub+ & Sub- can be used either differentially (BTL) or in Single-Ended (SE).
    If you need to use it Single-Ended (i.e. use either one of the outputs), I would recommend to make the following updates..
    1.) Update Register 0x20 to set Ch-6 in AD mode (default is BD mode). AD-mode is set by toggling the Bit-D3 of register 0x20 to '0'.
    2.) Update the ICD register's 0x15 & 0x16 to x04 & xFC respectively. (Default is xD0, x90).
    Register 0x25 can be left at default setting for both cases (BTL/SE).
    Register 0x21 can be set to either down-mix (L+R)/2 or bass-management.
    Ravi
    Ravi Singh
    Report Abuse
    • Reply
  • Hanns
    Posted by Hanns
    on Apr 23 2012 02:18 AM
    Hi Ravi and thanks for answering.
    I want SE mode since I'm connecting it to an external active subwoofer (i.e. a regular standalone consumer product thing).
    I'll implement the mods you recommended and in the meantime, here's a couple of follow-up questions for you:
    1) Does the SE-setup mean that I should use Sub-/Sub+ as signal and ground respectively or should I use Sub+ and regular ground?
    2) What is the difference between a) down-mix (L+R)/2 and b) bass-management?
    Again thanks!
    Report Abuse
    • Reply
  • Ravi Singh
    on May 15 2012 14:10 PM
    Verified Answer
    Verified by Hanns
    Hi Hanns,
    For the SE setup, the regular ground should be used for reference.
    Down-mix is simply the L+R/2 summation, while Bass-Management is a little bit of legacy feature, that combines Ch-6 with a ratio of the other channels. The following block diagram illustrates the differnet mux options for register 0x21
    Ravi Singh
    Report Abuse
    • Reply
  • Hanns
    Posted by Hanns
    on May 31 2012 15:54 PM
    Hello again Ravi,
    I've tested the configuration changes you suggested and it works well.
    I use the down-mix (L+R)/2 mode and take out the bass signal between sub+ and gnd which is then low pass filtered (130Hz cut-off) and then fed to an active subwoofer.
    Thanks for all the help!
    Hanns
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
