• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Amplifiers » Audio Amplifiers » Audio Amplifiers Forum » TPA6021A4 Clipping
Share
Audio Amplifiers
  • Forum
  • E2E Wiki
Options
  • Subscribe via RSS
Check out
Analog Wire blog
  • $core_v2_blog.Current.Name
    RS-485 - Who says you can't teach an old dog new tricks?
    Posted 3 days ago
    by Neel Seshan
    Would you agree that RS-485 has turned out to be one of the most...
    Filter for thought
    Posted 4 days ago
    by Soufiane Bendaoud
    Have you ever wondered how engineers designed active filters...
    Let’s take this driver out for a spin
    Posted 10 days ago
    Before I suggest a suitable op amp to drive an ADC, I look at...
TPA6021A4 Clipping
TPA6021A4 Clipping
This question is answered
Chris Walters
Posted by Chris Walters
on Apr 17 2012 17:14 PM
Prodigy30 points
I'm using the TPA6021A4 in an audio application. I'm feeding this from a I2S DAC chip. I've tried both CS4334 and MAX5555 with the same results. I seem to be getting clipping I'm using a sine wave to test the circuit. My TPA6021A4 is connected per Figure 19 in the datasheet, p. 11. The connection between it and the DAC is shown in the attached schematic.jpg. I've also attached two scope traces. Both have the yellow trace as the DAC output after the RC filter before the 0.47uF cap. The green trace is the output of the amplifier. "sine-gnd-bypass.jpg" occurs when "Lin -" is hooked per the TPA datasheet, bypassed to gnd with 0.47uF. "sine-floating.jpg" occurs when I unhook the Lin - capacitor and let the line float. The clipping disappears but full volume isn't achieved. If I reduce the volume enough the clipping goes away, but then the output is not very loud at all. Any recommendations to get this amp working without the clipping?
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Alfredo B.
    Posted by Alfredo B.
    on May 04 2012 10:09 AM
    Expert6275 points
    Hi Chris,
    What is your supply voltage and gain setting?  I assume you have configured the Amplifier in BTL mode?  What speaker impedance are you using?  I can't see the scaling on your scope capture very well, but it seems to be 2V/div?
    Alfredo Barriga
    Audio applications Engineer
    Dallas, TX - USA
    Report Abuse
    • Reply
  • Chris Walters
    on May 06 2012 20:11 PM
    Prodigy30 points
    Thanks for the reply. My supply voltage is 5v. I am using BTL mode. Everything is just like it shows in the example schematic. I'm using 4ohm speakers. The scaling is 2V/div. The input signal is ~3.2Vpp and the output being clipped is ~5Vpp. I'm using maximium gain, eg. 5v on volume pin. I can reduce the clipping by lowering the volume pin voltage or by adding some resistors to lower voltage of the input signal. The problem is that then the resulting volume I end up with is way to quiet. Initially I've used this chip with another DAC (differential) and was able to get much more volume.
    I suspect my problem has something to do with using a single ended DAC with a differential amplifier. I'm following the interface shown in the datasheet but it dosn't work correctly.
    Chris Walters
    Report Abuse
    • Reply
  • Alfredo B.
    on May 07 2012 17:14 PM
    Verified Answer
    Verified by Don Dapkus
    Expert6275 points
    Hi Chris,
    Yes, since you are applying a single-ended signal you will only get half of the output swing.  Ideally you would want to lower the gain and apply the input signal differentially, or the amp will clip since you are driving only half of it.  You can try lowering your speaker impedance but THD may be compromised.
    Alfredo
    Report Abuse
    • Reply
  • Don Dapkus
    Posted by Don Dapkus
    on May 10 2012 08:51 AM
    Guru101765 points
    Hi, Chris,
    Further to what Alfredo said... It looks like you are getting rail to rail swing on the output. I think the only way you're going to get more power is to use a higher voltage amplifier. I think if you look at the output differentially (ch1-ch2) and do the math, you'll see you're getting the rated output power, aren't you?
    I don't know the exact signal swing (you can calc it based on the plots in the d/s for 4-ohm load), but I'd guess driving 4 ohms you ought to be able to get 4Vpp on each output, which, measured differentially, will result in 8Vpp in BTL mode. By my calculations, this will give you about 2W of output power.
    -d2
    Don Dapkus
    Audio Applications Engineering Manager
    Dallas, TX USA
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
