• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Amplifiers » Audio Amplifiers » Audio Amplifiers Forum » TAS5613A
Share
Audio Amplifiers
  • Forum
  • E2E Wiki
Options
  • Subscribe via RSS
Check out
Analog Wire blog
  • $core_v2_blog.Current.Name
    This amplifier doesn't exist...now what!?
    Posted 1 day ago
    by Xavier Ramus
    Sometimes it’s impossible to find an amplifier with the...
    Cable equalization 101 – Automating your design
    Posted 4 days ago
    by Hooman Hashemi
    Judging by the number of views on a post related to numerical...
    RS-485 - Who says you can't teach an old dog new tricks?
    Posted 8 days ago
    by Neel Seshan
    Would you agree that RS-485 has turned out to be one of the most...
TAS5613A
TAS5613A
This question has suggested answer(s)
Sreekanth Anegunda
Posted by Sreekanth Anegunda
on Apr 18 2012 05:36 AM
Prodigy135 points
HI,
I am using TAS5613A power amplifier to drive audio signal (3.5KHz to 4KHz) in PBTL mode. The Load resistance will be around 9-10Ohm. I have constructed the schematics as given in the datasheet, what i noticed is the Output (out A, B, C, D) doesn't have the filter capacitor.
Does it require a filter capacitor in series with the Load and output, if not why we don't need?
Does the load gets damaged if we are not using a series capacitor?
Sreekanth
TAS5613A
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Don Dapkus
    Posted by Don Dapkus
    on Apr 18 2012 09:27 AM
    Guru102005 points
    Hi, Sreehanth,
    Please review this Design Note which I believe addresses your concerns.
    -d2
    Don Dapkus
    Audio Applications Engineering Manager
    Dallas, TX USA
    Report Abuse
    • Reply
  • Sreekanth Anegunda
    on Jul 09 2012 05:11 AM
    Prodigy135 points
    Hello Don Dapkus,
    Thanks for your reply on my earlier post.
    We have the output noise issue (Hiss) and the input current is High  in Ideal mode, I have constructed the schematics as in Demo board (OPA 1632+TAS5613A). I am applying 35V to the bridge of Power amplifier. The 35V supply current is around 120mA, But in datasheet its around43mA(12V+Half bridge current) when in Ideal. I have configured the power amplifier to PBTL (BD mode).
    I am giving the input to A and B (C is connected to VREG and D is connected to GND). What we observed is Hiss noise at the output (connected Speaker with 9-10Ohm load). Speaker has a frequency response till 16KHz.
    I connecting the preamplifier input to GND for verification, when both input are grounded  we won't hear any HISS but when any one input is grounded then we will hear the HISS at the output (And when input is open also we hear HISS).
    I have attached the Schematics of preamplifier and Power amplifier schematics.
    2844.Power amplifier.pdf
    2072.Preamplifier.pdf
    Sreekanth
    TAS5613A Output Noise
    Report Abuse
    • Reply
  • Don Dapkus
    on Jul 10 2012 07:15 AM
    Guru102005 points
    Hi, Sreekanth,
    We are unable to open the file, "Power Amplifier.pdf"
    It generates an error on our computers.
    Can you re-generate it and re-post it?
    -d2
    Don Dapkus
    Dallas, TX USA
    Report Abuse
    • Reply
    on Jul 10 2012 07:30 AM
    Prodigy135 points
    Hi Don Dapkus,
    Please find Attached power amplifier PDF.
    Sreekanth
    Report Abuse
    • Reply
    on Jul 10 2012 07:35 AM
    Prodigy135 points
    Hello Don Dapkus,
    Please find attached Power amplifier PDF.
    8585.Power amplifier.pdf
    Sreekanth
    Report Abuse
    • Reply
  • Don Dapkus
    on Jul 10 2012 09:26 AM
    Guru102005 points
    Sreehanth,
    Great! Thank you.
    Jade will get back with you shortly on this issue.
    -d2
    Don Dapkus
    Dallas, TX USA
    Report Abuse
    • Reply
  • Jade Goo
    Posted by Jade Goo
    on Jul 10 2012 16:54 PM
    Prodigy140 points
    Hi, Sreekanth,
    I checked your schematic.
    Also, I want to check your layout, too.
    Could you post your layout?
    Thank you.
    Jade
    Report Abuse
    • Reply
    on Jul 11 2012 00:17 AM
    Prodigy135 points
    Hi jade,
    How are you jade?
    Hope schematics is fine.
    I cannot post Layout as it is confidential.
    If you can give your mail Id then i can send it to you.
    Sreekanth
    Report Abuse
    • Reply
  • Don Dapkus
    on Jul 15 2012 09:28 AM
    Guru102005 points
    Hi, Sreekanth,
    Sorry for the delay. One of the guys is looking at your question.
    -d2
    Don Dapkus
    Dallas, TX USA
    Report Abuse
    • Reply
    on Jul 16 2012 01:40 AM
    Prodigy135 points
    Hello Don Dapkus,
    Mr Jade goo requested for PCB layout and i have sent them already But not received any comments or suggestion from him.
    looking forward for solution.
    Sreekanth
    Report Abuse
    • Reply
    Prodigy135 points
    Hello All,
    I am using TAS5613A for one of our product, I have constructed the schematics as in Demo board (OPA 1632+TAS5613A). I am applying 35V to the bridge of Power amplifier. The 35V supply current is around 120mA, But in datasheet its around43mA when no input is applied. I have configured the power amplifier to PBTL (BD mode).
    I am giving the input to A and B (C is connected to VREG and D is connected to GND). What we observed is there is Hiss noise at the output (Speaker with 9-10Ohm load).
    I tried connecting the preamplifier input to GND for verification, when both input are grounded the we won't hear any HISS but when any one input is grounded then we will hear the HISS at the output (And when input is open also we hear HISS).
    TAS5613A
    Report Abuse
    • Reply
  • Jade Goo
    Posted by Jade Goo
    on Jul 17 2012 10:36 AM
    Suggested Answer
    Prodigy140 points
    Hi Sreekanth,
    I checked your schematic and layout.
    1. I found Audio Preamplifier(IC401) output connect to blocking capacitor(C313. C319) and connect to INPUT_A, B of TAS5613A.
      Preamplifier output source is voltage and TAS5613A input source is voltage, too.
      In this case, preamplifier output impedance is low impedance and TAS5613A input impedance is high impedance.
      So, blocking capacitor(C313, C319) need to placed near TAS5613A input pin, because of impedance value difference.
      Trace length between the 5613A input pin and the blocking capacitor is susceptible to noise pick-up, and this distance should be minimized.
    2. Also, I want to know your board's output integrated noise(Vn), in case of datasheet, Vn was 185uV.
      Could you measured your board’s output integrated noise and please let me know.
    Thank you.
    Report Abuse
    • Reply
    on Jul 18 2012 02:12 AM
    Prodigy135 points
    Hi Jade,
    Thank you for your review on our PCB layout.
    I am are using a square heatsink for power amplifier so the DC blocking capacitors are bit far from the input of power amplifier.
    What i observed is when no input is connected to the pre amplifier we wont hear any noise, but if i ground any one input of pre amplifier we start hearing noise at the output.
    i tried grounding both the input of pre amplifier but the result is same.
    i don't know what is the reason for that.
    Looking forward for your earliest reply.
    I will measure the output integrated noise and let you know the same.
    Thanks & regards,
    Sreekanth
    Report Abuse
    • Reply
    on Jul 23 2012 03:14 AM
    Prodigy135 points
    HI Jade,
    I have not received any update from your side waiting for your reply.
    Sreekanth
    TAS5613A
    Report Abuse
    • Reply
  • Don Dapkus
    on Jul 31 2012 08:52 AM
    Guru102005 points
    Sreekanth,
    Could it be that your ground is noisy and injecting noise into the amp?
    Did you get a chance to measure the noise floor? And FFT might be useful, too.
    -d2
    Don Dapkus
    Dallas, TX USA
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
