• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Amplifiers » Audio Amplifiers » Audio Amplifiers Forum » TPA3004D2 VAROUT Outputs
Share
Audio Amplifiers
  • Forum
  • E2E Wiki
Options
  • Subscribe via RSS
Check out
Analog Wire blog
  • $core_v2_blog.Current.Name
    This amplifier doesn't exist...now what!?
    Posted 10 hours ago
    by Xavier Ramus
    Sometimes it’s impossible to find an amplifier with the...
    Cable equalization 101 – Automating your design
    Posted 3 days ago
    by Hooman Hashemi
    Judging by the number of views on a post related to numerical...
    RS-485 - Who says you can't teach an old dog new tricks?
    Posted 7 days ago
    by Neel Seshan
    Would you agree that RS-485 has turned out to be one of the most...
This question is answered
Jesse Baker80397
Posted by Jesse Baker80397
on Apr 30 2012 11:29 AM
Prodigy30 points
I have created a small test PCB to evaluate the TPA3004D2.  My application requires a single (mono) speaker with headphone outputs.  I used a slightly modified version of the schematic in figure 36 (page 21) of the TPA3004D2 datasheet. http://www.ti.com/lit/ds/slos407e/slos407e.pdf  The main modifications are that I am not using the left channel, so the left channel inputs are AC coupled to ground. The left channel Class D outputs are setup the same as the right channel outputs, execpt instead of driving a speaker, I inserted a dummy load (8 ohm resistor). The left channel VAROUT is terminated with a 10K ohm resistor. The right channel VAROUT output drives both channels of the TPA6110A2 headphone amplifier.
When testing the board with an audio input, the Class D outputs seem to work just fine. However there is no signal coming out of either of the VAROUT outputs. I have tried every possible combination of voltages (within the range of 0-VREF) on VARDIFF, VARMAX, and VOLUME pins, but the VAROUT pins remain constant with only a DC voltage of approximately 2.5V (same voltage as on the V2P5 pin). I used an oscilloscope to probe the VAROUT traces both before and after the DC blocking capacitors. I have also verified that the physical PCB traces were ok and not shorted to ground or any other pin/trace.  I thought that maybe the the VAROUT circuit was somehow damaged in the IC, so I replaced the TPA3004D2 with a new chip and the new chip performs in the exact same way.
Do you know of any possible cause for the VAROUT outputs not working?
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Don Dapkus
    Posted by Don Dapkus
    on May 04 2012 07:12 AM
    Guru101995 points
    Hi, Jesse,
    Sorry for the delay. I'm not sure what's going on here, Figure 36 was actually used by a major TV manufacturer many years ago to product several million TVs, AND, we test the VAROUT functionality....
    The fact that you get V2P5 at the outputs is a great sign! This means the op amp is properly biased. I expect the problem is with your volume setting. Please review the d/s where it discusses the volume setting of the VAROUT_x pins and give it another try. It sounds like your VAROUT volume setting is very low...
    -d2
    Don Dapkus
    Audio Applications Engineering Manager
    Dallas, TX USA
    Report Abuse
    • Reply
  • Don Dapkus
    on May 14 2012 21:09 PM
    Guru101995 points
    Hi, Jesse,
    Any update?
    -d2
    Don Dapkus
    Dallas, TX USA
    Report Abuse
    • Reply
  • Jesse Baker80397
    on May 15 2012 10:46 AM
    Verified Answer
    Verified by Don Dapkus
    Prodigy30 points
    Hi Don,
    Unfortunately the project that this was going to be used in was just cancelled, so I have not gone into any more debugging.  However, I don't think it was my volume setting. When I first realized that no audio signal was coming out of the VAROUT pins, I adjusted the voltages to give a maximum output (VARDIFF = 0V, VARMAX = VREF, VOLUME = VREF). When that didn't work, I then tried all combinations of voltages (from 0V - VREF) between the VARDIFF, VARMAX, and VOLUME pins. Still I received no audio signal on the VAROUT pins.  I also verified that  these voltages were in fact getting to their corresponding  physical pins on the IC (No shorts or bad solder joints). I guess this will just have to go unsolved.  Thanks for your Input.
    Jesse
    Report Abuse
    • Reply
  • Paul C. Chen
    Posted by Paul C. Chen
    on May 15 2012 19:52 PM
    Mastermind18130 points
    Hi Jesse,
    Have you tried disconnecting VAROUT  from the TPA6110 and see if VAROUT works?
    reg,
    Paul Chen.
    Dallas TX USA.
    Report Abuse
    • Reply
  • Jesse Baker80397
    on May 16 2012 08:50 AM
    Prodigy30 points
    Hi Paul,
    Yes, I disconnected the VAROUT pins from the inputs of the TPA6110 and probed them on the oscilloscope (with an audio input to the TPA3004D2) and still nothing but 2.5V DC on the VAROUT pins.  I then bypassed the TPA3004D2 and fed the input directly to the TPA6100 and I was able to get audio through the headphones, so I know that the headphone amplifier works.
    Jesse
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
