• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Amplifiers » Audio Amplifiers » Audio Amplifiers Forum » Electrically conductive thermal grease for TAS5630BDKD
Share
Audio Amplifiers
  • Forum
  • E2E Wiki
Options
  • Subscribe via RSS
Check out
Analog Wire blog
  • $core_v2_blog.Current.Name
    RS-485 - Who says you can't teach an old dog new tricks?
    Posted 4 days ago
    by Neel Seshan
    Would you agree that RS-485 has turned out to be one of the most...
    Filter for thought
    Posted 5 days ago
    by Soufiane Bendaoud
    Have you ever wondered how engineers designed active filters...
    Let’s take this driver out for a spin
    Posted 11 days ago
    Before I suggest a suitable op amp to drive an ADC, I look at...
This question is answered
Russell May
Posted by Russell May
on May 03 2012 13:56 PM
Intellectual675 points
Ti has recommended Arctic Silver Céramique as a thermal grease but it is not electrically conductive, so the required electrical contact to the topside thermal tab is incidental. Are there electrically conductive thermal greases you can recommend? We anticipate using Chemtronics CW7100 (http://www.chemtronics.com/products/americas/TDS/Cw7100tds.pdf). If there is a preferred choice, I would like to know about it.
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Don Dapkus
    Posted by Don Dapkus
    on May 03 2012 17:15 PM
    Guru101855 points
    Hey, Russell,
    Steve is out of the office right now, but he'll be back next week to help you with this.
    -d2
    Don Dapkus
    Audio Applications Engineering Manager
    Dallas, TX USA
    Report Abuse
    • Reply
  • SteveCrump
    Posted by SteveCrump
    on May 07 2012 17:19 PM
    Verified Answer
    Verified by SteveCrump
    Mastermind18510 points
    Russell, proper application of Ceramique actually produces reasonable resistance and capacitance between a heatsink and a PowerPAD, in spite of the fact that the Ceramique data sheet says (as you accurately mention) "It is a pure electrical insulator, neither electrically conductive nor capacitive."  In application as TI recommends Ceramique is compressed to a thickness of 1 to 2 mils, and we expect resistance in the range of several ohms to several kilohms and capacitance of 150pF or more in that condition.  (Ceramique actually has some conductivity and dielectric constant, though both are small, and that plus the thinness of the layer and the likelihood of some slight metal-to-metal contact at surface irregularities are behind the resistance and capacitance results I noted above.)
    Please DO NOT use thermal compounds with high electrical conductivity or capacitance, UNLESS you can be certain the compound cannot migrate to the pins of the ICs to which it is applied.  Compounds with either of those characteristics can cause partial or near shorts, resistive or capacitive.  You do not want to have to troubleshoot that...  Also, please DO NOT use thermal compounds that are not mechanically stable under prolonged pressure and heat.  These can migrate out of the target contact area.  We have found that Ceramique eliminates these problems.
    I should add that we get fairly frequent inquiries from customers complaining of unstable operation and poor audio performance, when they have used truly non-conductive thermal pads (with low capacitance) or have even insulated the PowerPAD or have not grounded the heatsink.  This problem is almost always eliminated with the use of Ceramique or an equivalent between the PowerPAD and the heatsink, with a solid heatsink ground.  We have worked with a variety of thermal compounds to arrive at our conclusions.  Part of our experience certainly was the pain of discovering the problems and issues I described above.  We do not want you to suffer through any of that.
    Steve.
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
