• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Amplifiers » Audio Amplifiers » Audio Amplifiers Forum » TAS5731 / TAS5711 subwoofer EQ question
Share
Audio Amplifiers
  • Forum
  • E2E Wiki
Options
  • Subscribe via RSS
Check out
Analog Wire blog
  • $core_v2_blog.Current.Name
    RS-485 - Who says you can't teach an old dog new tricks?
    Posted 1 day ago
    by Neel Seshan
    Would you agree that RS-485 has turned out to be one of the most...
    Filter for thought
    Posted 2 days ago
    by Soufiane Bendaoud
    Have you ever wondered how engineers designed active filters...
    Let’s take this driver out for a spin
    Posted 8 days ago
    Before I suggest a suitable op amp to drive an ADC, I look at...
This question is not answered
Jon Zenor
Posted by Jon Zenor
on Jun 21 2012 10:02 AM
Prodigy40 points
We are using the TAS5731 in a 2.1 channel design.  The subwoofer signal path only has 2 bi-quads available and we need another 1 or 2 to meet our goals.  I've been staring at the block diagram trying to find a novel solution and may have found one if the diagram is showing what I think it is.
So the question I have concerns the apparent signal path from the left channel (between the 6 BQ filters and the single BQ filter) to the switch before the bi-quads in the sub channel.  Does this path really exist and what was it's intended purpose?
What I would like to do is use the first bi-quads in the left and right channels to create a hi-Q, HP filter (to give the sub some low end boost),  then use mixer 55 and BQ 5E to low-pass the right channel signal before mixing it back in with the left channel with mixer 53.  So then this summed signal would be sent to the sub channel using the path mentioned above.  Then BQs 59 and 5D would be high-pass filters to remove the low frequency (and thus right channel signal).
Would this work as I think it will?  Thanks!
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Clancy Soehren
    Posted by Clancy Soehren
    on Jun 21 2012 14:49 PM
    Intellectual2225 points
    Your plan could work, but if you tell me more about what your objectives are, I might be able to give you a better answer.  This would probably meet your subwoofer needs, since you would essentially have a couple of extra filters to shape the signal with.  One of my concerns is that you might not be able to tune the left and right channels as much as you might want to.  Your manipulations to get the best subwoofer signal might alter the left and right channel content enough so that one filter isn't enough to correct it.
    The original purpose for the signal path from the left channel to the MUX in the subchannel was to allow for a 2.0 two band DRC application.  This allows you to run the DRC algorithm for low and high frequency content separately.
    TAS5731
    Report Abuse
    • Reply
  • Jon Zenor
    Posted by Jon Zenor
    on Jun 21 2012 15:23 PM
    Prodigy40 points
    It is a very small, self contained 2.1 system and only having 2 bi-quads (one high-pass, one low-pass) has not been enough to optimize our bass response.  Essentially, if we tune the HP low enough (with a high Q to give us some extra extension) then we end up with a "saddle" in our acoustic response between that filter and the LP filter.  If we move the HP up enough to flatten our response then our needed LF extension goes away.
    So our acoustics engineer would like another filter (or two) in the sub woofer channel.  If there is another way with this IC I'm all ears.
    I'm not super concerned about tuning the L & R signals as we only need a couple of EQ filters to optimize that acoustic response (and the HP to filter the sub frequencies).   So using some of the other BQs in the L & R signal paths will be OK and shouldn't effect what we're trying to do with the sub.  I know this will likely require a little more trial and error as we overcome any interactions between the desired signals.
    Is there a way to implement this in the GUI?  Thanks!
    Report Abuse
    • Reply
  • Clancy Soehren
    on Jun 22 2012 11:48 AM
    Jon,
    I don't see another way to give you an extra filter for the subwoofer, still have separate left/right channels, and have both the left and right channels' content in the subwoofer.  Since what you are suggesting isn't what this part was designed for, I can't guarantee that you'll be able to tune the part enough to meet your needs.  If you really need the extra filters for the subwoofer, then your scheme is worth a try.
    One more thing to consider before going down this road is a different filter design.  Maybe try using a bass shelf followed by a low pass filter.  The current version of the GUI doesn't design that type of filter, but you can input the filter coefficients manually.
    TAS5731
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
