• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Amplifiers » Audio Amplifiers » Audio Amplifiers Forum » OPA1632 Unity Gain Stable?
Share
Audio Amplifiers
  • Forum
  • E2E Wiki
Options
  • Subscribe via RSS
Check out
Analog Wire blog
  • $core_v2_blog.Current.Name
    This amplifier doesn't exist...now what!?
    Posted 6 hours ago
    by Xavier Ramus
    Sometimes it’s impossible to find an amplifier with the...
    Cable equalization 101 – Automating your design
    Posted 2 days ago
    by Hooman Hashemi
    Judging by the number of views on a post related to numerical...
    RS-485 - Who says you can't teach an old dog new tricks?
    Posted 6 days ago
    by Neel Seshan
    Would you agree that RS-485 has turned out to be one of the most...
This question has suggested answer(s)
Kevin Godfrey
Posted by Kevin Godfrey
on Jul 27 2012 09:32 AM
Prodigy40 points
Good day
I would like to use the OPA1632 in a balanced audio driver application. I would like to know if this device is unity gain stable, and what the maximum allowed load capacitance is.  As this will be driving long audio cables, I need to know what the limitations are.  Alternatively, is there a different fully differential amplifier that you can suggest? Thanx. Kevin
opa1632
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Don Dapkus
    Posted by Don Dapkus
    on Jul 31 2012 20:24 PM
    Guru101995 points
    Hi, Kevin,
    Did you look at the DRV134?
    -d2
    Don Dapkus
    Audio Applications Engineering Manager
    Dallas, TX USA
    Report Abuse
    • Reply
  • Kevin Godfrey
    on Aug 02 2012 05:20 AM
    Prodigy40 points
    Hi Don. Thank you for your feedback.  I have used the DRV134 before, really is a great device, but only has single ended input. I require a device that is balanced in and balanced out, so the OPA1632 is a good option.  I am just concerned with driving long lenghts of cables with it, if it would remain stable like the DRV134 is. Looking forward to your feedback. Thanx
    Report Abuse
    • Reply
  • Randy S
    Posted by Randy S
    on Aug 06 2012 11:33 AM
    Intellectual2780 points
    Kevin,
    The OPA1632 datasheet has a bandwidth line item spec for unity gain and a plot or two in the apps section showing unity gain performance. So the first answer is yes, it is unity gain stable.
    As for Capacitive loading – this part is a high speed amplifier and is more sensitive to capacitive loading placed directly on the output. It can safely handle up to about 5pF to 10pF in unity gain configuration. But as this capacitance increases, more and more peaking will occur which can result in instability.
    There are several options to consider. The most common is to place a series resistor on each output pin of the OPA1632. It is recommended to use at least 20-ohms palced very close (<10mm is ideal). There are other methods to isolate the capacitive loading such as a similar configuration as Fig 11 in the OPA1632 datasheet shows or even use a ferrite chip instead of a resistor with a low-Q and say 80 ohms @ 100MHz of impedance.
    Cheers,
    Randy
    Report Abuse
    • Reply
  • Ranji Bhola
    Posted by Ranji Bhola
    on Aug 06 2012 19:15 PM
    Suggested Answer
    Intellectual1510 points
    Kevin,
    Looking at an alternative fully differential amp is a recommended route as a low power alternative would be helpful while still providing excellent audio performance with low quicescent current.
    A low power alternative to the OPA1632 is the THS4521, although the THS4521 does not have quite as low a noise spec as the OPA1632 and the BW is slightly lower at 145MHz vs 180MHz.
    I would be able to porvide more recommendations; could you provide me with the key specs you are looking to meet? (BW, Noise figures, THD, Distortion, etc.)
    Also, do you have an ADC in mind already? We have a variety of ADCs that may be suitable for your design.
    Ranji C. Bhola
    High-Speed Amplifiers
    Ranji C. Bhola
    Report Abuse
    • Reply
  • Kevin Godfrey
    on Aug 09 2012 08:54 AM
    Prodigy40 points
    Hi All
    Thank you for your comments so far.
    This will not be used to drive an ADC directly.  It will be used in an application where a balanced audio signal will be split before being distributed to two remote audio units, over balanced audio cable of about 100 metres.  So first, since it is for analog audio application, the BW can be less.  Also, will typically be used in a mode where gain =1. Requirements are for lowest noise possible, and needs to be stable with long lenghts of cable.  (typical requirements for high audio fidelity applications).
    Let me know if you need more info please.  Thanx
    Report Abuse
    • Reply
  • Ranji Bhola
    on Aug 09 2012 17:45 PM
    Suggested Answer
    Hello Kevin,
    I would recommend the THS4531, the BW is within the audio range, the min stable Acl gain (V/V) is 1, and the quiescent current is 0.25mA per channel which is a dramatic improvement over the OPA1632. This fully differential amplifier should fit your application needs.
    There is a detailed section for Audio performance in the THS4531 datasheet including audio on/off pop performance, THD+N, and FFT test data of the device performance in the audio band.
    Please let me know if you have further concerns.
    Ranji C. Bhola
    Ranji C. Bhola
    Report Abuse
    • Reply
  • Kevin Godfrey
    on Aug 22 2012 15:53 PM
    Prodigy40 points
    Hi Ranji
    Thank you very much for your assistance in this regard .I will have a look at the devices you suggested.  Will let you know if I have any additional questions.
    Kevin
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
