• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Amplifiers » Audio Amplifiers » Audio Amplifiers Forum » LM48901
Share
Audio Amplifiers
  • Forum
  • E2E Wiki
Options
  • Subscribe via RSS
Check out
Analog Wire blog
  • $core_v2_blog.Current.Name
    RS-485 - Who says you can't teach an old dog new tricks?
    Posted 2 days ago
    by Neel Seshan
    Would you agree that RS-485 has turned out to be one of the most...
    Filter for thought
    Posted 3 days ago
    by Soufiane Bendaoud
    Have you ever wondered how engineers designed active filters...
    Let’s take this driver out for a spin
    Posted 9 days ago
    Before I suggest a suitable op amp to drive an ADC, I look at...
LM48901
LM48901
This question is answered
tirthraj chandake
Posted by tirthraj chandake
on Aug 13 2012 11:16 AM
Prodigy60 points
Hi
Can you please review attached schematic for LM48901LLP. My requirement is only analog audio input so I removed SPDIF source and redesigned board. Also designed for 4-speaker to 16-speaker configurable (Master-Slave). Please suggest any correction needed.
I have few question please clarify.
1. What is the use of EEPROM (AT24C512) in reference design. It is always disconnected by jumper.
2. Any option to AARDVARK USB-I2C device? Can there any alternate option to Load Coefficients?
3. Any special requirements for power supply. Can we use SMPS based power input? will it effect quality?
4. If we design PCB with 2 layer can quality affect?
5141.LM48901LLP_Schematic.pdf
Thanks & Regards,
Tirthraj
LM48901
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Royce Higashi
    Posted by Royce Higashi
    on Aug 13 2012 14:56 PM
    Verified Answer
    Verified by tirthraj chandake
    Expert3350 points
    Tirthraj,
    1. The EEPROM is there so that the EVM user can load coefficeints and device setups into the 901 without needing to connect to a PC.
    2. The GUI was designed for either the Aardvark or TI's USB2ANY USB to I2C interface.  If you are not using the GUI and have a different I2C controller, just connect the SDA, SCL and GND lines to the jumper.
    3. The 901 works fine with SMPS power supplies.  As with any audio design, make sure the supply is well bypassed and regulated.  More importantly, make sure the supply has more than enough current headroom.  The 901 will make very unappetizing screeching sounds if the supply collapses due to current limitations.
    4. As long as you can provide good ground and supply routing, while keeping the inputs away from noise sources.
    Schematic:
    The I2C_EN connection on the daisy chain output connector should actually be I2C_EX.  I2C_EX is the output of the preceding device that drives the I2C_EN of the following device, once the preceding device is completely configured.
    royce
    Report Abuse
    • Reply
  • tirthraj chandake
    on Aug 14 2012 08:10 AM
    Prodigy60 points
    Thanks Royce,
    As per my understanding
    1.  If I download coefficeints generated from web tool directly to EEPROM and I connect SDA, SCL and GND to LM48901 then it works.
    2.  I can download coefficeints in EEPROM using any generic USB-I2C adapter or through microcontroller.
    3.  LM48901 read data from EEPROM on "POWER ON"
    4. GUI is only required for debug, equalizer and some extra optional settings.
    Please correct my understanding if any.
    Please provide information of "TI's USB2ANY USB to I2C interface" product. link from TI site and purchase information.
    Thank you very much for quick support.
    Thanks & Regards,
    Tirthraj
    Report Abuse
    • Reply
  • Royce Higashi
    on Aug 14 2012 16:43 PM
    Expert3350 points
    Trithraj,
    While you can program the EEPROM independently, I would suggest using the LM48901 to write to the EEPROM.  That way the device writes the configuration and coefficient data to the proper memory addresses in the EEPROM.  Use the GUI to program the 48901 with the coefficients ahd the desired configuration settings, then go to the EEPROM tab, select the device and click on the Write to eeprom button. This will cause the LM48901 to dump all its register contents to the EEPROM.  Once that is complete, any time you power up the device, it will automatically read from the EEPROM.  Make sure you use the latest version of the GUI (3.7.0.0) available at TI.com.
    I'm looking for any documentation on the USB2ANY.  I would suggest getting in touch with your TI sales rep for ordering information.  The USB2Any serves as a replacement for the Aardvark, so if you have an Aardvark, you don't need the USB2ANY at this time.
    royce
    Report Abuse
    • Reply
  • tirthraj chandake
    on Aug 15 2012 21:55 PM
    Prodigy60 points
    Thanks Royce,
    I dont have Aardvark tool.
    Is the following tool same you are talking about USB-ANY (http://www.ti.com/tool/usb-to-gpio). if other than this then please provide information.
    In the web tool  of Spatial Audio Speaker Designer help I found "Range of input" that is
    distance from the listener to the origin should be within 40 and
    100cm. Error message will prompt if user inputs are out of range.
    but in it gives error massage after 500cm. so which one is correct.
    Thanks & Regards,
    Tirthraj
    Report Abuse
    • Reply
  • Royce Higashi
    on Aug 17 2012 18:36 PM
    Expert3350 points
    Tirthraj,
    The USB2ANY is only available with our EVMs.  If you order a LM48901 EVM, you will also receive a USB2ANY.  Aardvarks are available for purchase direct from Total Phase.
    The spatial effect works best when the listener is between 40-100cm away.  But the design tool will allow you to create coefficients for up 500cm distances.
    REgards,
    royce
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
