Hi All,
Can you please let us know if we don't configure the TAS2505 audio amplifier, does it works by its default configuration if we play an audio?
MCU->TAS2505->Speaker.
BR,
Vageesh
Hi All,
BR,
Vageesh
Hi, Vageesh,
Most likely not as this device is very flexible, and the default register settings may not be compatible with your system's settings (clocking, I2S format, etc, etc).
Please check the Applications Reference Guide; you can find it here.
For example, page 49 has a sample script for a typical system.
Let us know if you have any further questions after reviewing this document.
-d2
Hi Don,
Can I connect 2 slave devices to TAS2505 over I2S and can play audio from each slave device one after other?
Or it works only for one slave connection?
