Please can you advise if it is possible (with correct tools and using the STI interface) to dial in biquads on the TPA3110D2 to filter off unwanted frequencies? Datasheet does not mention anything regarding Biquads.
I am using 2pcs in a design and need one to run 0-160hz and the other to run 160hz-20khz
The development is at quite a late stage and the DSP which was supposed to act as the crossover has a bug and does not work properly in 2.1 mode so I am hoping there is some way around this, by accessing the biquads.
