Hi TI Folks,
May check with you what is the TAS5630B max current specification for VDD @VDD=12V for worst case situation?Thanks.
Weiren
Hi TI Folks,
Weiren
Hi, Weiren,
The TAS5630B is a class-D amplifier. This makes your question a little bit complicated.
Unlike a class-AB amplifier where the supply current = the load current, for a class-D amplifier, the supply POWER = the load POWER.
So, you need to determine the maximum power that could be delivered to your load, divide that by the efficiency of the amp, and then convert that power back into a current from your 12V power supply.
-d2
Hi Don,
Sorry for the late reply. Thanks for sharing the information. But I am a bit confuse. The power for the amplifier should be taken care of by the PVDD_X right? The VDD should be mainly for the TAS5630B internal logic operation right?
Weiren
Weiren,
The nominal VDD current is about 22.5mA. There is no max spec but should not be much more than nominal value. Place a bulk cap close to VDD pin to take care of any narrow in rush current.
reg,
Paul.
