What is the minimum PWM input pulse width to which the TAS5631B will response. What is the effect of having a series of very short pulses?
I presently am working on an issue with our DSP PWM generator which delivers bursts of pulses of 32ns when set for 0dBFS.
More specifically, At 400KHz rate what is the minimum pulse width the TAS5631B will accept. Also what occurs if the pulse width becomes even shorter?
The T.I. datasheet would be enhanced if they stated what the minimum pulse width is and a commentary about events to expect if the pulses are much shorter.
This is urgent.
David
