Dear All,
I have a question.
My customer was comparing the data sheet of TAS5538 the TAS5558.
So there was no part of the described in the TAS5558.
The contents following description.
Data Manual Page36
• The samples input into the DRC are 32-bit words and consist of the upper 32 bits of the 48-bit word
format used by the digital audio processor (DAP). The 48-bit DAP word is derived from the 32-bit serial
data received at the serial-audio receive port by adding 8 bits of headroom above the 32-bit word and
8 bits of computational precision below the 32-bit word. If the audio-processing steps between the SAP
input and the DRC input result in no accumulative boost or cut, the DRC operates on the 8 bits of
headroom and the 24 MSBs of the audio sample. Under these conditions, a 0-dB (maximum value)
audio sample (0x7FFF FFFF) is seen at the DRC input as a –48-dB sample (8 bits × –6 dB/bit = –48
dB).
Headroom of TAS5538 According to this it has been described as a 48dB but there is no information in the TAS5558.
I've confirmed it is assumed that the 24dB in the data sheet and PPConsole.
Please tell us about this difference.
Y.Hasebe
