I'm working to drive TAS5614LA as BTL 3ohm and found adding shottky diode (CR1-CR4) on each OUTPUT pins in TAS5614LA EVK's schematic below.
Could you tell me the reason why these shottky diode are needed in case of 3ohm load?
In addition, the document said that ROC should be changed to 22ohm in case of 3ohm load. Please also tell me why.
