TAS5342A Pin status
Guru 16770 points
Other Parts Discussed in Thread: TAS5342A
Hi
I have a question about IO pin state of TAS5342A.
Is it possible to input pwm signal to PWM pins when the device is power off (any power is not supplied)?
regards,
  • Hi Na,
    Generally is not recommended to provide any input to the device if they are not fully powered on. This device will keep the H-Bridge outputs in a High-Impedance state until power supply levels are over the Under Voltage Protection.
      -Diego Meléndez López
       Audio Applications Engineer
