Hi team,
My customer GGEC is using TAS5731 in their ODM project. But some IC broken in their end customer. Now, because they don't have board in their hand. Could you please help to check the SCH? Many thanks. TAS5371-SCH.pdf
Hi team,
Hi Martin,
Could you please provide more information about the issue your customer is meeting?,
I looked at the schematic and I noticed that you are using 10µF decoupling capacitors, we usually recommend to use 0.1µF low ESR ceramic capacitors located as close as possible to PVDD pins to avoid any high frequency ringing at the output of the device. Also, if possible can you please provide the schematic of the board?
Thanks and Best Regards,
-Diego Meléndez López
Audio Applications Engineer
