Hello
We are thinking on using a LPF filter (LC) on the power supply of the DAC (to remove high frequency noise) with a cutoff frequency of 100Khz-150Khz
Instead of that we can also use the DSP function of the PCM5122 to make a LPF (with same cutoff frequency)
What do you recommend ? If both filters are applied do you see any advantage ?
thank you
