• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Amplifiers » Audio Amplifiers » Audio Amplifiers Forum » Can the TAS5630 drive a HF transformer?
Share
Audio Amplifiers
  • Forum
  • E2E Wiki
Options
  • Subscribe via RSS
Check out
Analog Wire blog
  • $core_v2_blog.Current.Name
    RS-485 - Who says you can't teach an old dog new tricks?
    Posted 3 days ago
    by Neel Seshan
    Would you agree that RS-485 has turned out to be one of the most...
    Filter for thought
    Posted 4 days ago
    by Soufiane Bendaoud
    Have you ever wondered how engineers designed active filters...
    Let’s take this driver out for a spin
    Posted 10 days ago
    Before I suggest a suitable op amp to drive an ADC, I look at...
This question is answered
jgorsk
Posted by jgorsk
on Dec 01 2009 09:28 AM
Prodigy20 points
I'd like to design a 'simple', high voltage AC source. Up to 280Vrms, 300 .. 400W, 50 .. 60Hz
Initially I was going to use a high power class AB audio amplifier to drive a low frequency
transformer. Then I found the TAS5630 class D amplifier. The use of class D amplifier could
make my device much smaller and lighter and would allow me to generate higher frequency
signals.
Can the TAS5630 drive a high frequency transformer?
Is the phase shift between various outputs of the TAS5630 controller and stable?
I would be ideal if I could use two primary windings connected in parallel and driven
by the differential outputs of the TAS5630: winding 1 OUT_A - OUT_B, winding 2 OUT_C - OUT_D.
jgorsk
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Kim Nordtorp Madsen
    Posted by Kim Nordtorp Madsen
    on Dec 09 2009 10:10 AM
    Verified Answer
    Verified by Don Dapkus
    Intellectual2335 points
    jgorsk
    If you what to pass 50-60Hz the transformer need to be sized to that - and thats big.
    rgds,
    Kim
    Report Abuse
    • Reply
  • jgorsk
    Posted by jgorsk
    on Dec 09 2009 11:07 AM
    Prodigy20 points
    Hello MIK,
    Thanks for your reply. I do relize that I need high power, bulky transformer to pass 50-60Hz signals.
    That's why I'd like to use class D amplifier and pass high frequency signals through a high frequency,
    small size transformer. My idea is to use the transformer instead of the choke and apply filtering
    at the secondary side of the transformer. 600W, TAS5630 based amplifier seems to be what I need.
    The primary winding can be (at least theoretically) connected between OUT_A and OUTB, a second
    primary (to increase the output power) could be connected between OUTC and OUT_D.
    I don't want to invest time and money before I make sure that the idea can work at all.
    The TAS5630 datasheet doesn't mention timing relations between AOU_A, B, C and D
    outputs in varius modes of output configurations. I need to know if the outputs are in phase, stable phase shifted or phase shift is random.
    Do you have access to a development kit to check the timings or is there more detailed documentation
    for the chip available?
    I know that application is way from 'standard' applications of class D amplifiers but could be interesting.
    At least for me. Maybe for you as well. Just think of the application notes you could write if that worked. [:)]
    Kind regards,
    jgorsk.
    Report Abuse
    • Reply
  • XinLi lai
    Posted by XinLi lai
    on Jan 06 2010 01:40 AM
    Prodigy20 points
    ok!I have succeed parrel   two tas5630 chip for POWER SOURCE,It can be used for current source or voltage source,
    If you interest it ,please connect me by mail .authlxl@gmail.com
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
