Hi TI,
we are using TAS5630B and the power supply voltage is 50V and the package is DKD.
We have seen that a few samples have had shorted outputs and exploded. We suspect dust to be the cause (the amplifier has fans). We wonder if antistatic carpets could be the reason, but can not verify this. To be on the safe side we will now test if PCB coating will help. The failure occurs after 2-3 years or more.
Have you seen before that dust can cause such a failure?
Do you think PCB coating will be a fix? The chip operate under changing temperature from ambient up to 90C.
Trond Wang
