Hi, I have 4 x PGA2500's on a pcb. I am using a shared +-5v supply between all 4 PGA2500's.
I have analogue ground and digital ground & 0v from +-5v supply all joined at one common point off the PCB
The digital supply is coming from the the -5v of the same power supply.
I have DCEN enabled by grounding to digital GND.
I am using 1uf caps between the DCEN capacitor pins.
The PGA2500's are warming up quickly so I assume something is very wrong in my design.
I have tried taking off 2 PGA2500's and now only have 2 soldering on. On my previous veroboard test design I disabled DCEN an eliminated the
chips overheating problem but I would like to enable the function in my design.
Can anyone advise me what i'm doing wrong here ? I have implemented diode protection with recommended diodes in data sheet but I have not included the
48v phantom power yet until I work out this problem !
Any ideas would be much welcome. perhaps I should not have connected 0v to GND ? or there is something wrong in my diode protection schematic that is causing dc to get to somewhere is should not ?
ben
