Hi team,
My customer, CVT, is using our TAS5733L. They found that if we put a 2k pull down resistor to ground during power-up, then there would be no PWM output on the output pin. If we remove the 2k pull down resistor, PWM will appear.
I have tested TAS5733L with our EVM in the lab, and the same thing happened.
Can you help explain why? Thanks.
Vio Liu
