I would like you to confirm above recommended voltage range for following pins.
* "STANDBYn","SDA","SCL"
The target voltage is 3.3V, but it seems that there is no description about voltage range in case of 3.3V.
Can we use same spec as "V(PU) (Pullup voltage supply (for open-drain logic outputs))" for above pis as well ?
Machida
