I'm using the tpa3125 for a single 8ohm speaker.
according to the datasheet, the output has 1 inductor in series and one capacitor to the GND for each output.
according to the Evaluation Board schematics, there is additional ferrite bead in series and more resistors/capacitors connected in parallel to GND.
I'm aware that the Evaluation Board schematics is for single ended configuration but I want to make sure what is the best practice for my application.
Moreover, some of the values of the capacitors/resistors are different between the Eval Board scheme and the application notes in the datasheet (for the same configuration) can you explain why?
many thanks
