I send data to PGA2311's SDI the same of high 8 bits and lower 8bits,but only VinR was amplified
Hi Echo,
To help me trouble shoot your issue can you please provide oscilloscope waveforms of the input and output of both channels, CS, SCLK, and SDI?
-Tim Claycomb
Hi Echo,
I do not see anything wrong with the timing of CS, SDI, or SCLK. Would it be possible to also provide data of the SDO pin with CS, SDI, SCLK? This may help us see what the PGA2311 is reading.
Are the left and right inputs the same? If not, what is the input to the left channel.
Lastly can you please provide your schematic?
-Tim Claycomb
Hi Echo,
I notice that there are two separate symbols for the digital and analog ground (GNDD and GNDA). Are these ground planes connected together at a single point somewhere on the PCB?
The PGA2311 datasheet recommends having two separate ground planes for the digital and analog ground but they must be connected at a single point. See section 10.1 of the PGA2311 datasheet.
-Tim Claycomb
Hi Echo,
Can you please post what the solution to your problem was? This way, if others in the future have a similar problem to yours they can quickly locate a solution.
