Hi Expert,
Two questions for TAS5756. Thanks!
1. I log the initial code from PPC2, you can check "PPC2 Log Data.TXT". And also use the LA to log I2C bus command, you can check "LA Log Data.TXT. You can see many difference between the two I2C command. Which file is right? Or both are fine?
2. Customer MCU download the command to TAS5756 will fail, but use the AIC3254 CS tool, it always good. Does TAS5756 I2C need to follow any timing Spec?
PPC2 Log Data.TXT
LA Log Data.TXT
TI AIC3254 GUI (the deltaT is 5.66mS)
Customer MCU (the deltaT is 648uS and 992uS)
