Hi Sirs,
We found the TPA3110's surface temperature becomes very hot in idle mode with low AVCC supply voltage with wrong 10kOhm input resistance at AVCC pin. It becomes normal with 10Ohm resistor replaced. Would you please advise why the low AVCC supply voltage could result high body temperature? Do we have AVCC power consumption data?
Thank you and Best regards,
Wayne Chen
02/20/2017
