Hello team,
The customer would like to change bootstrap capacitors (4pcs) from 0.22uF to 0.47uF or 1uF. Although I do not think TI can recomend capacitor change, they would like TI to advise as the following.
1) Does TPA3118 have any issue if the bootstrap capacitors change from 0.22uF to 0.47uF or 1uF? I think that THD+N performance would be changed. Is it correct? if it is right, anything else?
2) Do you think that changing from 0.22uF to 0.47uF or 1uF causes TPA3118 brake?
If you would like to know why I ask you about Bootstrap capacitors, I will send email in offline.
Your advise would be so aprrecated.
Akihisa Tamazaki
