My company has a design that has been successfully using the TAS5630B for several years. We've built around 70 units to date with no issues. But, recently, one of our units has a TAS5630B that is taking an unusually long time to set READY signal high following power-up. When we apply power to this chip, shutdown signal SD goes low (i.e. chip in shutdown) and stays low for around 0.5 second. Once SD goes high, READY goes high and the chip appears to function correctly afterwards. In our design, we need to know how long the chip requires to be ready to transmit (worse case). Our design waits 60ms before transmitting and this has always been more than sufficient time. This particular unit has been working in the field for 2 years and only recently starting exhibiting this behavior.
We're trying to determine if this issue is caused by something internal to the IC or by an external component. Does anyone have any ideas or suggestions?
