Other Parts Discussed in Thread: TAS5756MDCAEVM, TAS5756M, TAS5754M
My motherboard dosen't match the PurePath Console2. (buy from taobao)
PLS check the problem for us.
TKS.
TKS.
Hi Jingran,
Before you launch PPC2 (PurePath Console 2), make sure TAS5756MDCAEVM is mounted to PurePath Console Mother Board. PPC2 will detect which board is connected when it is running.
Andy
I can run my PurePath Console by mounting the TAS5756MDCAEVM now.
How can I export the current register table from the PurePath Console?
I changed the configuration and made sure it had been effected.
i exported 4 files from the System Build Tab. So which one could guide me to config the PA on my board?
I found the register tableInit_9a.cfg (the 4 files) was same as which I didn't config any more (default value).
thank u, Andy.
I had dumped the register table from the Register Dump Console.
How can I read the table I had dumped?
w 98 00 00
w 98 7f 00
w 98 00 00
w 98 00 00
w 98 00 00
w 98 7f 00
w 98 00 00
w 98 03 11
# page 0 dump
for example :w 98 7f 00
Does it means the register address is 0x7f, and the register value is 0x00? The page num is 0?EQ-CFG.cfg
Thank U Andy..
There are two more questions:
1. How could I distinguish the pages in configuring.
My datasheet doesn't include the sequence of the I2C configuration, and lacks the detail description of the registers as well.
So do you have the documents contain both the sequence and the details? If can, pls send to me.
2. Does the character string "# page 45 (0x2D)" point upward or downward?
w 98 7b 00
w 98 7c 00
w 98 7d 00
w 98 7e 00
w 98 7f 00
# page 45 (0x2D)
w 98 00 00
w 98 7f 00
w 98 00 2d
w 98 00 2d
w 98 00 00
Any line starting with # is a comment. It has nothing to do with any i2c command.
thank u Andy.
do u have any documents describe all registers in all register pages?and how to config the registers in different pages?
it would be kind if u send to me.
Is there anyone knows which document describe the hole details of all the registers about TAS5756M?
Could U pls send me any document? lijingran@baidu.com
Hi Jingran,
Details of the registers on Page 0 & 1 can be found in the TAS5754M datasheet. TAS5754M and TAS5756M share the same register map.
Andy
