Other Parts Discussed in Thread: TAS5760XXEVM
There is the point that doesn't obey the power-on sequence which is mentioned for PBTL configuration in TAS5760M data sheet as below.
Do you have any concerns when /SPK_SD pin is de-asserted to "high" for several seconds if the external components are set in PBTL configuration before setting the registers via I2C bus after the power-on ?
At this time, I2C clocks have already been applied to TAS5760M but the zero data is input to TAS5760M as the audio source.
Kato
