Hi team,
The customer uses TPA3128D2. He refers to Figure 36. TPA312xD2 Schematic of the datasheet.
He uses the MASTER mode and Gain is set 26dB. When his board is powered on, the FAULTZ pin is low.
So I let the customer refer to Table 4. Fault Reporting to find his issue. Then I will update the post.
Now the customer would like to verify if he needs to refer to Figure 29 Timing Requirement for SDZ of the datasheet to
start the TPA3128D2 device, then the TPA3128D2 device will work well. Would you verify this?
The FAULTZ pin is low, would you provide some suggestions?
Best Wishes,
Mickey Zhang
Asia Customer Support Center
Texas Instruments
