Other Parts Discussed in Thread: TAS5760M
Could you please give me your advice about the following questions ?
Q1. PWM Switching Frequency
Should the pwm switching frequency(the configuration for AM2/1/0 pins) be same if using a couple of TPA3116D2 with the master and slave synchronization mode ?
Q2. Slave Synchronization Mode
Is it possible to use a couple of TAS5760M with the slave synchronization mode only without the master device ?
Please tell me the external clock frequency which can be applied to SYNC pin if possible.
Kato
