can I use the INA139 as low side Monitor? Will tie In- to Gnd and In+ to my shunt. I will use an independant supply for the INA139 (15V.
Thanks a lot for helping.
With best regards
Gerhard
Hello Gerhard,
Unfortunately, you can not use the INA139 below a common voltage of 2.7V. In a low side configuration this will not work properly. I would suggest an INA210 for the low-side measurement. There are a few gain versions of this device one should fit you application.
Jamieson Wardall
Sensing Applications
