Hi, Kindly advise how to design the FILTER for the current output from XTR115U
Atul Bhakay
Hello Atul,
From the .PDF file it looks like your question is "What's the best way to filter a PWM signal so it can be used as an input to the XTR115 device?"
We recommend a multi-order passive filter followed by a low supply current op amp used to buffer the filtered PWM signal to the inputs of the transmitter. A simplified example of this is shown below based on the XTR117.
You can reduce the number of passive RC stages based on your ripple requirements.
