Sir,
I have been into designing of sensorless control of switched reluctance motor where i need to sense the voltage across the winding. the system voltage is 48V, 3 A (max). Is there any products that will suit my need....
Thank you,
Pragash.A
Sir,
Thank you,
Pragash.A
I just saw the schematics there as it is three phase BLDC, sensing the voltage with respect to ground is not a problem. But here it is switched reluctance motor, where the winding will be inline between the two switches of the asymmetric converter. So there may be switching disturbances caused due to the low side MOSFET switch right...
But it may also work and i will try implementing it.
Thank you,
Pragash.A
I believe the INA240 is a good choice to investigate for your application, if you have a 48V PWM signal and inline implementation of the current sense resistor. There's an introductory app note about different implementations of current sensing for motors that details a bit about the INA240 and how it performs in an inline PWM application. There is also a short "Tech Note" about inline current measurement that highlights the INA240 and a few other alternative devices.
Let us know if that gets you started or if we've misunderstood your application needs and can provide better input. We're here to help!
