• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Amplifiers » /etc... Amplifiers & Other Linear » /etc... Amplifiers & Other Linear Forum » Recommended Buffer or Follower for Photodiode Amplifier Circuit
Share
  • Forum
  • Announcements
  • E2E Wiki
Options
  • Subscribe via RSS
This question is not answered
Sean Krzyzewski
Posted by Sean Krzyzewski
on Sep 09 2011 13:16 PM
Prodigy40 points
I am attempting to create a photodidoe amplifier circuit used for detecting fluorescence from an atomic source and cannot determine the type of buffer/follower OP AMP I should use when trying to convert the high impedance from the photodiode circuit to the low impedance necessary for the 50 Ohm BNC cable. I am currently considering BUF602 or BUF 634, but am open to other suggestions. I have attached a drawing of the circuit.
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Bruce Trump
    Posted by Bruce Trump
    on Sep 10 2011 07:28 AM
    Mastermind21545 points
    Sean,
    It's not clear that you need a buffer in your situation. What is the bandwidth required for your measurement? How long is the cable that connects to your measurement system? What type of instrument are you connecting to (what is its input impedance)? Answers to these questions will help determine whether you need a buffer.
    Regards, Bruce.
    Is a buffer needed to drive a coax cable?
    Report Abuse
    • Reply
  • Neil Albaugh
    Posted by Neil Albaugh
    on Sep 10 2011 11:18 AM
    Genius4945 points
    Sean;
    We also need to know the capacitance of the photodiode and its expected signal current. You will probably need a transimpedance amplifier for your application.
    Regards, Neil P. Albaugh   ex-Burr-Brown
    photodiode transimpedance amplifier flourescence
    Report Abuse
    • Reply
  • Sean Krzyzewski
    on Sep 12 2011 13:56 PM
    Prodigy40 points
    Hello and thank you for the quick reply. I have attached the specifications of the photodiode I will be using (Thorlabs FDS100). I believe this has the relevant information you have asked for on the photodiode (i.e. Bandwidth=35 MHz, Capacitance=40 pF). The BNC cable I will be using is roughly 10 feet long and is connected to an oscilliscope (Tektronix TDS 380) with a 1 M Ohm input impedance.
    Report Abuse
    • Reply
  • Neil Albaugh
    on Sep 12 2011 14:23 PM
    Genius4945 points
    Sean;
    Your requirements are not going to be trivial--- A photodiode with 40 pF @ -10V will be difficult to deal with if you need much sensitivity from your fast photodetector circuit. A much smaller PIN photodiode will be far easier to deal with than one with an active area of 13 sq mm. Is it possible to use a much smaller active area device? If you chose the large photodiode because you need to capture more photons, consider using a very small detector with a lens or mirror to focus the large collecting area on a small active area. Optical gain is noise-free, so take advantage of it wherever you can.
    You did not say how much photocurrent you expect from your detector.
    photodiode
    Report Abuse
    • Reply
  • Sean Krzyzewski
    on Sep 13 2011 09:57 AM
    Prodigy40 points
    Neil,
    Sorry about not including the expected photocurrent earlier, I must have missed that point. We expect a photocurrent somewhere between roughly 100 nA and 100 microA  depending on the measurement. Unfortunately, using a smaller photodiode would severely hamper the measurements I will be taking. I will be using a lens in the set-up, but the measurements technique I will use requires that the image (the diameter of the image will be about 1 inch) and the object size be equivalent, so I will already be greatly reducing the amount I will image. Thus, using a smaller photodiode further enhances this issue. Hopefully there is a way to design the circuit while still using the larger photodiode. Thanks once again for all the help.
    Sean
    Report Abuse
    • Reply
  • Neil Albaugh
    on Sep 13 2011 14:06 PM
    Genius4945 points
    Fast TZA.TSC
    Sean;
    No optics, eh? Well, we will "endeavour to persevere" as Chief Dan George said.
    I have attached a circuit that uses a fast current feedback amplifier in a transimpedance amplifier configuration with your 40pF Thor photodiode. I've placed a 5-pole passive L-C low pass filter on the amplifier output to eliminate the out-of-band noise to improve your SNR. You might want to add a second amplifier just after the transimpedance amplifier to bump up the signal level but that depends on your scope sensitivity and resolution. High-speed digital scopes have a pretty poor noise floor and you want to be limited by the detector noise, not the scope.
    photodiode TZA
    Report Abuse
    • Reply
  • Sean Krzyzewski
    on Sep 15 2011 15:18 PM
    Prodigy40 points
    Thank you Neil very much for the help. I truly appreciate it.
    Report Abuse
    • Reply
  • Neil Albaugh
    on Sep 15 2011 19:12 PM
    Genius4945 points
    You're welcome, Sean.
    Report Abuse
    • Reply
  • releas
    Posted by releas
    on Jul 16 2012 15:44 PM
    Prodigy50 points
    hello, i dont understund your op choice (the ths3201), for what reason you dont used some opa that have fet input?
    eneas
    Report Abuse
    • Reply
  • Carlos Ignacio Sarmiento
    Posted by Carlos Ignacio Sarmiento
    on Jul 18 2012 14:57 PM
    Prodigy20 points
    I was weeing your amplifier circuit, but I should you to have more low gain steps than use high value resistors, they must cause noise...
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
