• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Amplifiers » /etc... Amplifiers & Other Linear » /etc... Amplifiers & Other Linear Forum » TLC393 Op-amp
Share
  • Forum
  • Announcements
  • E2E Wiki
Options
  • Subscribe via RSS
TLC393 Op-amp
TLC393 Op-amp
This question is not answered
Deepak Bansal
Posted by Deepak Bansal
on Feb 14 2012 07:30 AM
Expert2395 points
1. I am using TLC393 op-amp as comparator with 15V supply.
2. Inverting terminal is connected with 1:1 voltage divider (10M each), by 3V voltage source.So that voltage at inverting terminal is 1.5V.
3. Non-inverting can be set high or low by pin of MSP430 with a 100K resistor . (3V high, 0V low.)
4. Attached find circuit diagram.
I don't understand why my op-amp  is getting damaged.
3250.on PDFCreator_.pdf
comparator TLC393
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • John Caldwell
    Posted by John Caldwell
    on Feb 14 2012 10:08 AM
    Expert6525 points
    Hi Deepak,
    I don't initially see anything wrong with your circuit, although the large resistor values may cause issues with response time. Could you describe how the part is being damaged? What I mean is are these failures visible (gets hot, smoke, etc) which would suggest excessive power dissipation or does the part just not function properly after a short period? Is the part installed on a pcb or a breadboard? It would also be sure to double check that the part is installed with the proper orientation, for example if the part is rotated 180 degrees it would definitely cause failures.
    John Caldwell
    Analog Applications Engineer
    PA Linear Apps
    Report Abuse
    • Reply
  • Deepak Bansal
    on Feb 15 2012 06:12 AM
    Expert2395 points
    John,
    After 2-3 minutes op-amp gets damaged with with smoke coming out of it. I tested it with 3 op-amps, all damaged like same.
    I am using breadboard for placing op-amp. i have tested circuit many times, no shorting b/w pins & no problem found.
    Report Abuse
    • Reply
  • Jayant Deshpande
    Posted by Jayant Deshpande
    on Feb 15 2012 06:24 AM
    Expert1255 points
    Deepak,
    Are you using different power sources for 15V and 3V ? Are you switching them on-off at the same time ? Are you ensuring that both 15V and 3V supplies are at 0V while inserting the comparators ?
    If the dV/dt is too high, the part can possibly go into SCR latchup and eventually destroy itself. Otherwise it could be an ESD issue. Can't say for sure !
    Let's see what TI's experts have to say...
    JayantD
    Report Abuse
    • Reply
  • Deepak Bansal
    on Feb 16 2012 02:59 AM
    Expert2395 points
    1. I am using single power supply of 15V & using voltage regulator for 3V. So both are turned off/on at same time.
    2. Yes power supply is turned on after proper connections.
    3. I have tested on 4 TLC393IP, all bursted from inside same way.
    Report Abuse
    • Reply
  • Jayant Deshpande
    on Feb 16 2012 03:34 AM
    Expert1255 points
    Deepak,
    The failures could be due to the effect of some other components in your circuit, which you have not shown in your attached pdf. It would help if you could post the complete schematic. Do you have decoupling capacitors on the power supplies ? Are you sure the 15V supply is clean, without any spikes?
    If the ground connection of a linear regulator floats, it's output equals the (unregulated) input. In such a case I would expect circuit behaviour as described by you.
    Please do a double-check and revert.
    JayantD
    Report Abuse
    • Reply
  • Deepak Bansal
    on Feb 16 2012 07:21 AM
    Expert2395 points
    Jayant,
    I have checked it. I don't see any problem in the ckt. I don't understand why this is happening?
    Report Abuse
    • Reply
  • Jayant Deshpande
    on Feb 16 2012 07:26 AM
    Expert1255 points
    Deepak,
    I hope the parts are genuine !
    JayantD
    Report Abuse
    • Reply
  • Deepak Bansal
    on Feb 16 2012 23:37 PM
    Expert2395 points
    I sourced it from TIeStore.
    Any comments/suggestions from TI's experts.
    Report Abuse
    • Reply
  • John Caldwell
    on Feb 17 2012 10:00 AM
    Expert6525 points
    Deepak,
    If you sampled the parts from us there should be no issues with them being genuine, and I see no issues with your schematic if it is indeed wired as you show. One method I recommend to help the debugging process is to put a resistor in series with the VDD pin (pin 8) on the part. That way any excess current draw by the part will be limited by this resistor and prevent the part from failing until we can track down the cause of these failures. If possible, could you take a picture of the circuit on your breadboard and post it here?
    John Caldwell
    PA Linear Apps
    Report Abuse
    • Reply
  • Deepak Bansal
    on Feb 20 2012 00:32 AM
    Expert2395 points
    John,
    I have checked same ckt but with LM339. It is working fine. But it has larger power ratings. I will check again on TLC with 10K resistor on VDD.
    What could be the probable reason for that.
    Deepak
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
