• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Amplifiers » /etc... Amplifiers & Other Linear » /etc... Amplifiers & Other Linear Forum » LMV358 Output issue
Share
  • Forum
  • Announcements
  • E2E Wiki
Options
  • Subscribe via RSS
LMV358 Output issue
LMV358 Output issue
This question is answered
Santhosh Ramani
Posted by Santhosh Ramani
on Mar 09 2012 14:31 PM
Expert1525 points
We are using the LMV358 in the voltage follower configuration - but are seeing strange results. The part clearly mentions that it is a rail to rail output - but for one of the opamp circuits never reaches the rail voltage while the other output does.
Has anyone seen anything like this, for a supply for 3.3V (VCC) and an input of 5V to both Opamp circuits in the voltage follower circuit - output of the first circuit is 3.3V but the second one max is 2.75V.
The exact part number is LMV358ID. The OpAmp output is directly fed to a microcontroller ADC channel input - even if I disconnect it from the Micro the output does not change.
Thank you for your help.
Santhosh
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Paul Grohe
    Posted by Paul Grohe
    on Mar 09 2012 14:58 PM
    Verified Answer
    Verified by Santhosh Ramani
    Expert4295 points
    Hello Santhosh,
    The LMV358 is a R-R output, but it is NOT a R-R input.
    In the follower configuration, Vin = Vout, which means Vout  is equal to the input common mode voltage.
    For the LMV358, the input voltage range is -0.2V to 1V below V+, or 2.3V max input for a 3.3V supply. This is specified on page 5 of the LMV358 datasheet by the "Common Mode Input Voltage  Range" line.
    The chain is only as good as the weakest link, and in this case the weakest link is the input. it is the input that cannot go above 2.5V.
    You have "lucked out" with one of the amplifers as it seems to be functioning at the higher common mode level - but that operation cannot be guaranteed.
    You need to use a Rail to Rail input device, like a LMV932MA or similar...
    More concerning is your statement: "for a supply for 3.3V (VCC) and an input of 5V to both Opamp circuits in the voltage follower circuit "
    Are you saying the op-amps supply is 3.3V and your input voltage is 5V?
    Obviously, you will not get a 5V output with a 3.3V supply - even with a R-R input device!
    And you are grossly violating the abs max input common mode range. Placing a voltage on the input higer than the supply voltage will cause the ESD diode to conduct current into the V+ line. This is not good and can damage the device.
    Paul Grohe
    SVA Precision Applications
    Paul Grohe
    Integrated Signal Chain Applications, SVA
    Report Abuse
    • Reply
  • Santhosh Ramani
    on Mar 09 2012 15:10 PM
    Expert1525 points
    Hello Paul,
    Thank you for your reply, I think made some basic mistakes in writing my post. I am not trying to get 5V output from a 3.3V VCC supply OpAmp.
    But I completely understand the CMIVR comment - I was testing the part and increased the input all the way to 5V during test and posted the same results.
    I now get that I was making a mistake.
    Thank you for your detailed answer.
    Santhosh
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
