• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Amplifiers » /etc... Amplifiers & Other Linear » /etc... Amplifiers & Other Linear Forum » LMV331 Input Voltage Range (V_CM)
Share
  • Forum
  • Announcements
  • E2E Wiki
Options
  • Subscribe via RSS
This question is answered
Zachary Glickstein
Posted by Zachary Glickstein
on Apr 17 2012 07:52 AM
Prodigy50 points
I am looking to clarify the meaning of the parameter V_CM, Input Voltage Range, from page 3 on the LMV331 datasheet.  This value is listed as -0.1V to 4.2V given a VCC of 5V, I am trying to verify if this relates to an absolute maximum for the inputs to the part or if it relates to the common mode input.
The input common mode voltage for an op-amp is (V_IN+ + V_IN-)/2, the name of the parameter implies an absolute range, but letters in the symbol, V_CM, implies this parameter relates to Voltage Common Mode.
With VCC=5V and one input being 4.5V and the other input being 2V will this violate the V_CM parameter for this component?
LMV331
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Paul Grohe
    Posted by Paul Grohe
    on Apr 17 2012 10:53 AM
    Verified Answer
    Verified by Zachary Glickstein
    Expert4295 points
    HI Zachary,
    The common mode limit is an absolute for each pin, not the average of the two pins. The formula is correct, but not applicable...
    Comparators can have differential voltages of several volts, so one input does not get a "free-pass" because the other input is at a much lower voltage.
    A VCM limit of 4.2V means do not go above 4.2V....
    So, yes, if one input is at 4.5V, you are violating the VCM specification, regardless of what  is on the other input.
    You will need a R-R input device like the LMC7215 or TLV3401.
    Paul Grohe
    Integrated Signal Chain Applications, SVA
    Report Abuse
    • Reply
  • Zachary Glickstein
    on Apr 17 2012 16:51 PM
    Prodigy50 points
    Thanks, this ansewers my question.
    Report Abuse
    • Reply
  • Ron Michallick
    Posted by Ron Michallick
    on Apr 18 2012 11:42 AM
    Verified Answer
    Verified by Ron Michallick
    Mastermind30440 points
    Zachary,
    The LMV331 only needs one input to be in the common mode range to have a valid output.
    If both inputs are above the maximum common mode range or either input is below ground then the output is undefined.
    Neither input should exceed VCC.
    Your example voltages will provide a good output.
    Ron
    Ronald Michallick
    Linear Applications
    TI assumes no liability for applications assistance or customer product design. Customer is fully responsible for all design decisions and engineering with regard to its products, including decisions relating to application of TI products. By providing technical information, TI does not intend to offer or provide engineering services or advice concerning Customer's design. If Customer desires engineering services, the Customer should rely on its retained employees and consultants and/or procure engineering services from a licensed professional engineer (LPE).
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
