• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Amplifiers » /etc... Amplifiers & Other Linear » /etc... Amplifiers & Other Linear Forum » DRV103 EMI problems
Share
  • Forum
  • Announcements
  • E2E Wiki
Options
  • Subscribe via RSS
DRV103 EMI problems
DRV103 EMI problems
This question is not answered
Andreas Marten
Posted by Andreas Marten
on Apr 18 2012 03:04 AM
Prodigy20 points
I've designed the DRV103 in a circuit like the aplication Circuit Figure 16. Remotely Opreated Solenoid Valve or Relay,
in the datasheet DRV103 (SBVS029A-June 2001).
Also the recommended 100pF capacitor parallel with Rpwm is used. The oscillator frequency is is adjust by a 200k resistor (Rfreq),
and the duty cycle is adjust with a 133k resistor (Rpwm).
Now I have problems with the EMI, and espacially with the electromagnetic field immunity test for EN61000-4-3.
It seems that the frequency and the duty cycle is not stable.
Please let me know if the problem is known, and what can I do to get rid of this fault.
Many thanks for your efforts.
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Bruce Trump
    Posted by Bruce Trump
    on Apr 18 2012 15:41 PM
    Mastermind20900 points
    Andreas,
    I'm sorry you are having difficulty using the DRV103. I have some questions to help diagnose the situation:
    Have looked at waveforms with an oscilloscope? Does the basic frequency look stable on the oscilloscope? You refer to unstable frequency and duty cycle. Can you quantify what you are experiencing? Do you see an unstable waveform as shown in the top of figure 6?
    RF interference can be caused by layout issues. Connections to the load should be made with twisted pair. The +Vs side of the twisted pair should be connected close the the DRV103 and its bypass capacitor. It is often better to locate the flyback diode close to the DRV103, not at the solenoid. The selection of the flyback diode can make a difference in RFI. Some slower diode types can create RF noise as they turn off. A fast-recovery type should be used.
    Regards, Bruce.
    DRV103 noise RFI
    Report Abuse
    • Reply
  • Andreas Marten
    on Apr 24 2012 03:50 AM
    Prodigy20 points
    3733.Screenshots.pdf
    Bruce,
    thanks for your help.
    in the PDF Screenshots you can see the waveform in differnt situations.
    Figure 1: This is the waveform with no disturbance.
    Figure 2-5 shows the waveform, when the conducted disturbance is activated.
    in this case the circuit is acted with the conducted disturbance of 5V(80%AM(1kHz)) at the 24V supply-line .
    The frequenz where the fault  appear's, is between 100MHz-300MHz.
    The disturbance is coupled by a injection Clamp to the 24V supply-line.
    We choose the test of conducted disturbance by EN61000-4-6 for the pre compliance test for the
    electromagnetic field immunity test by EN61000-4-3.
    We must test with 10V/m by EN61000-4-6. this should be equal 8-10V by conducted disturbance with
    the injection clamp, because we have seen, that the disturbance is coupled by the lines to the unit.
    The only way I found to protect the DRV103 against this disturbance is a extern Filter in the
    24V supply line, but this is not practicabe.
    Do you know a protective circuit at the DRV103 which solve the Problem too?
    I think the problem is not causes by the flyback diode, because we have the same problems, when
    we have a normal resistor as load.
    Regards Andreas.
    Report Abuse
    • Reply
  • Bruce Trump
    on Apr 24 2012 19:06 PM
    Andreas,
    Thanks for the additional information. I'm not surprised that 5V of 100MHz to 300MHz on the supply voltage of the DRV103 causes problems with its operation. This level of high frequency voltage would be very disruptive to internal circuitry.
    You are assuming that the radiated RF field has a fixed relationship to the conducted level on the 24V power line. I think the solution must be to change this expected relationship. This could come from a various measures:
    • Improved bypassing of the 24V power supply. The correct choice of capacitors can make a very big difference. For example, X2Y capacitors can be selected to provide very low impedance in the sensitive frequency range. You may want to experiment with other capacitor values and types, located near the device power connections.
    • Routing of supply and load wiring can make a difference. Are you using twisted pair connections to the load? Can these connections be moved closer to a ground plane? Can shielding be added?
    I hope this helps.
    Regards, Bruce.
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
