Hi all,
Would you mind if we ask TL084?
The datasheet defined Vicr 12V to 15V in case of Vcc+=+15V, Vcc-=-15V.
So, in case of Vcc+=15V, Vcc-=0V, how much will it be?
We could not find it from the datasheet.
Kind regards,
Hirotaka Matsumoto
Hi all,
Kind regards,
Hirotaka Matsumoto
Hirotaka-san,
It is a simple translation based on the supply rails.
VCC+ did not change so top common mode range is +15V
VCC- changed by +15V therefore bottom range is -12V + 15V = +3V
The typical common mode range will be +3V to +15V.
