I am using PGA309 with a sensor in output voltage mode, need to do multi point temperature calibration. since i am using 0-10V outtput with a sensor (PGA+ output buffer) I will not be able to use the EVM software for this temperature calibration.
is there any document that helps with calibration flow and also computing calibration coefficients?
I understand from documents that the temp comp of zero and Span are done through piece wise linear interpolation. it would be helpful if any such documents are shared to help me do this multi point temp calibration
thanks and regards,
Sudheer
