What is the output voltage swing range when the LT1013, LT1013A, LT1013D are operated at +-22V supply? Also what is the common-mode voltage range at this supply? Does the slew rate change from a +-15V supply?
What are the gain bandwidth products for these parts?
Also when using in the single mode what is the supply voltage range? Can only the LT1013 be used in the single mode?
