Hi everyone,
I have an 8-pins chip. The top and bottom figures are shown below. Who knows what chip it is?
I am looking forward to your reply.
Thanks!
Hi everyone,
Thanks!
Hi Luxing,
If you go to any Product folder page, click on the Order now tab, then under the Device marking column click View. In the new page that pops-up, click on the Part marking lookup. Click Search by Marking on the part, then enter 3721 in the Search phrase box, then Lookup.
What is returned is a list of devices, however, in this case, no match is found. I had at first thought this to be a TPS7A3721, however these are only in a WSON (no leads) package, not SOIC.
So, after all that, we're still no closer to finding out what this device truly is! Let me research this some more.
Where did this device come from? Was it on a circuit board, and if so, what are the marking on the board? Who is the manufacturer?
And finally, there is a possibility it is a counterfeit device.
More to follow . . .
~Leonard
This is the product, correct?: http://www.mouser.com/ds/2/328/1SD210F2-FZ750R65KE3-612511.pdf . Technical manual is here: https://gate-driver.power.com/sites/default/files/product_document/application_manual/1SD210F2_Manual.pdf , but no schematic, and yes, there is a comparator for VCE monitoring.
You may have to go to Concept website, technical support, ask for a schematic.
Hello Luxing,
When I do an internal search on TI device marking codes one possibility that I arrive upon is the TLE2037MD. It is a precision operational amplifier available in the 8-pin (D) SOIC package. There are a number of analog circuits in the IGBT driver circuit tha appear to be using operational amplifiers.
You can find the datasheet here:
Regards, Thomas
Precision Amplifiers Applications Engineering
